1 - 16 of 16 Posts
I have a stiff steering cable. How can I take the cable out and lube it? I have a Teleflex NFB rack and pinon steering system and a legend jet pump. I don't think that I should have to get a new cable if the one I have only needs some grease.
Unlike some things once those things get stiff Once the cable gets that way its pretty much done, my pops once spent days hanging one from close line and lubeing it with WD , New rack systems are relatively inexpensive and simple to install ;) Tom
Holy cables batman!!!:)grn
What the Hell is That?
Tom,
Steering is a little tight on my end too. :mad:
I wont be able to tear into it until next week though.
Tom,
Always check your "steer tube" for adjustment , the tendancy is to overtighten the bushing nuts and the steer tube must move ever so slightly back and forth to compensate for the swing of the tiller ,If the tube is too tight it will cause the steering to bind and be stiff, A good working rack should be "pinky finger operation" out of the water, Also having a swivel clevis (about 20 bucks)at the end of the rack shaft helps alot ;) Tom
Discussion Starter · #9 ·
steer tube Adj
Ok Tom I will admit it I have no clue. Where do I adjust the steering tube? I have a U clamp that the cable jacket clamps to the jetovator cable mount
I have always lubed my cables. In fact I did that to my current boat, you couldn`t turn the wheel when I got it. The trick is more power:)grn. If you let gravity do the work there is not much chance of it working....however, if you get a piece of clear hose, clamp it on over the end, (after you loosened the inner guide, sorry I don`t have a cable nearby so no pics) then you fill the hose with some w-d40. Now for the important part.....put a quick disconnect on the other end of the hose and hook it to the aircompressor:)devil. After you force some wd40 through you can move to heavier trans fluid or whatever the oil of your choice is.
Like this?
I tried this too. and it worked grate. After a few months the cable did start to get stiff again. I left the hose connected with WD 40 in side the tube for a weekend with the pressure set at 15lbs.
Boat Nut
If you know it's going bad , plan on replacing it....cause it's gonna bite you when you least expect it. Being unable to make your trip, or unable to steer your boat, both unacceptable scenarios IMO
I saw replacement cables from 99 - 140 bucks. I would not even worry about lubing that sucker and just replace it. Not worth it getting stuck while on the water. Looks like tommy has a few sittin around just call him and get one shipped to you.. I cant imagine it would be difficult to replace.
Just change the cable . I had one break on me , thank god I was going slow. That could have been very bad :mad:
21 Daytona
Do yourself a favor when you install that new steering cable...... add one of these to yoursteering tube.
it has an O-ring seal and a grease zerk. screws on the end of the steering tube and will prevent
H2O from entering the new cable.:)devil
just call tom(jbp) and get a new cable, he will hook you up. and do what outlaw said and get the grease fitting adapter for the new cable. speak from experience....on two different boats..
1 - 16 of 16 Posts
