1 - 9 of 9 Posts
Does this steering sprocket look worn out if so where can I score one quick
Thanks
It turns but it seems like the pictured gear is stripped unfortunately not one part number anywhere!
I replaced my whole steering deal, It was cheaper than parts.
That's a Command 290, its was superseded by the Teleflex Safe-t. Don't believe the Teleflex helm is backwards compatible with the Morse cable though. Either the Telflex or the Uflex systems are direct replacements for the entire setup.
It's on a 94 Lavey..do you know the part# for the teleflex I should look for and is it necessary to replace the cable as well?
Thanks
Why are those such pieces of sloppy crap that you have to buy a whole new box? Mine has a ton of play also. Was going to take it apart, but it doesn't look like there is anything to fix.
That's the same conclusion I'm coming to. Thanks guys I really appreciate it. JBP my buddy is going to give you guys a call tomorrow. Thanks again
1 - 9 of 9 Posts
