1 - 20 of 24 Posts
might wanna check valvetrain geometry 1st;)
Aluminum heads w/ roller springs...IMO it's a given.
Uh...before I mount my 049's should I consider ARP rocker studs, or just stick with the OE GM's ?
170 seat, 425 over the nose >5200 rpm
Village Idiot
If you are using stud girdles you don't need new studs as the girdles help support the studs. If you were going with monster springs I might say yes.
Paul
BTC cardcarrying member
JOM 1113 JOMAR PRO-MODEL ROCKER ARM STUD GIRDLE
Chevy 396-502 Pro-Model Girdle Bars, fits head w/stock stud location The Jomar Pro-Model Stud Girdle is the best on the market today. The advantages... $167.58
21 Daytona
Dons correct get the 1113, the adjusting nuts come with the girdles so dont buy aditional ones.
2 of my buddy's are running the 1113 and i just installed the 1114 on my AFR's
perfect fit on all three.
Dons correct get the 1113, the adjusting nuts come with the girdles so dont buy aditional ones....
Nope, they don't or at least not anymore..earler today I ordered the 1113 Jomar's from Teague, the rep said ...> "yep comes with everything".
Well, later today he called my cell and said...> "sorry I was wrong the poly locks are extra"...I cancled the order. :)st
21 Daytona
that SUX,
just a ski boat with bark
For what it's worth an old CompCams 4021 stud girdle I picked up used on a GM 990 head. It fit fine just a little more hassle than say the Websters.
1 - 20 of 24 Posts
