1 - 2 of 2 Posts
hi im a pro master mech, heavy equipment/ cranes but im in a jam always building n/a bbc DRAG JETS they have run good,fast but im now hooked on the hard stuff seeking advise on my new project its a nice 26 velocity w/bravo 1 stockermpi ief 454 mag i have following on hand 1 454 gen 5 block 1 454 steel .010/.010,under 1 set 6385 /arp L19 h beams 1 set 502 rods 1set .030 aris blower pistons,2 gmpp ported alum heads +.100 around 345 runner set up for a 710lift,solidw/man svr duty +.100in/ex 225/188 arp pro series main/head studs arp long rocker studs crane wide rockers w/girdle,1 set cust +.100 push rods weldon big fuel pump,pro charger m3sc/504, 1 set 50# injectors for the merc intake,1 pr emi thunder ex,with silent choice, 1 billet adjustable timming chain,1 12qt pan ,1 msd 7ml 3 box msd slip coller 1 set comp cam hyd rollers, seeking advise on finnishing up this im getting withdrawl symptoms need cam recomendaitions for wet ex/blower ,ring mfg/style,end gap/gap spacing piston/wall clerance, inconel ex valves,good hyd springs,head gasket style oil pump that will work with a milodon support/tray, cam c/l starting point,how mant ponies will it make and whats needed for drive improvements please help a fiberglass junkie out sir pleeeeeaaaaassssseeee thanks
Official Test Driver
Sounds like you have a decent parts list. Can you send a pic of the current bilge/ rear set up? Also what are you intending on doing. Race pleasure?
1 - 2 of 2 Posts
