1 - 5 of 5 Posts
what is the inside bore measurement of the older dominator suction housing that used the smaller od wear ring.?
PRE 1984, believe there was only 2 different od wear rings the "earlier" and the standard od wear ring that is used today. believe it is the same measurement as the a.t. conversion ring for the jacuzzi conversion kit. need the measurement of the inside diameter where the wear ring goes.
1 - 5 of 5 Posts
