B1 Racing
I went to the dyno running c16 and we got A/F tuned for that fuel...Im planning on switching fuels. What are the numbers or specs I need to look at to compare fuels? specific gravity? concerned about my jetting by switching fuels.
Looking at going from VP c16 to F&L 118.
Thanks for any help.
Chris
B.A.M aka "Black Azz Mike
Doesnt brian(Busby) know the answer to this? These are some good tech questions Chris:) I wouldnt mind learning about fuel as well.
Spitter
CS,
Your fuel rep should be able to tell you. As you stated the biggest thing is sp. gra.,but also oxygen content (%).
The C-16 has a sp. grav. of .735 and the F& L is .700 ( .68-.72 tolerance) from the F & L web site : " Heavier weights flow less volume through a given opening".
Get a good rep on the phone or re-dyno. :)bulb
Sleeper CP
Big Inch Ford Lover:D
B1 Racing
Discussion Starter · #4 ·
Talked to some people about this, basically they said only concern if any was the jetting. A lighter fuel has a different affect at the jet than a heavier fuel. The fuels are so close Im told its probably okay but it wouldnt hurt to bump up the jetting 2 sizes and get a plug reading or better yet hook up an a/f ratio deal. I will probably do both.
Its strange that F&L has a range on their specific gravity, didnt see that with other fuel manufacturers.
What is your reason for switching fuels? Just curious.
Neither did I, but when you think about it they are all made with a tolerance. I doubt they can always hit the same number, so +/- a small % is reasonable.
Sleeper CP :D
Chris
Chris although my boat is slow we sell FnL sp3 here at work. Its all i use for about 7.70 a gal. last time i checked. Theirs 113 116 & 120 octaine.
