1 - 7 of 7 Posts
Broke Member
Yeah I couldnt get the motor high enough to get over the transom without puling the manifold so I just grabbed a tow truck from work. Much easier.
As far as I can tell its a 454 with dual carbs and rewarder stacks. Not sure if it's bored over or not thought.
OK am I the only one that noticed this bowl is upside down. The oil fill holes are on the bottom of the bowl.:no:
If that motor has a vdrive oil pan and pickup on it it's not gonna work. That motor came out of a vdrive right? Pick up would be on the wrong end of the motor am I right? First time he gasses it the engine will be starved for oil Pull the pan and make sure .
1 - 7 of 7 Posts
