temp sender
1371 Views 10 Replies 6 Participants Last post by  SuperSoaker
on a elc. temp sender is it ok to shorten the end that go's into the water/oil
passage???
It's about 1/2" long would like to cut it down about 3/16 to 1/4".
I'm useing it in a oil passage and trying not to block to much of it.
gen 5 block, going in one of the oil cooler plugs by the pan.
THANKS
1 - 11 of 11 Posts
passage???
THANKS
Get a different sender, like a 1/8th NPT sender, and screw it into an adapter, then into the block.
I have 2 of the 1/8 senders but thay dont read right and have no# on them.
Have one with 3/8 npt that reads right.
I'm going to look tomorrow and see if I can put my oil press. in that hole and put the temp in the hole right above the oil filter pad
Next time I pull the pan I will weld one in it.
I'm thinking maybe screw a short nipple in the hole, screw on a coupler, then the sender?
Tim
Just go with the oroginal MikeT strap-on...I did :)sphss
Thanks everyone I got it all figured out now.:)hand
What would I do with out this site:D
I think Rat is the next one in line to get a MikeT strap-on:D
Last I heard it was on back order............due to supply in demand!:rolleyes:
With the MikeT post I found a 1/8th sender, and I have a 3/8th npt to 1/8th bushing that will fit the block. Which is what I had just wrong sender and APITA to get to:mad:
Rat the shop is open for you, same story as last time to get in if im not home:)devil
1 - 11 of 11 Posts
