1 - 20 of 858 Posts
Hey Ron, how about elaborating on the turbo build you are getting ready to put together and what hp you are wanting to get. thanks
Wow put me on the spot. :)
First things first. We are doing our normal thing. We are using what we have lying around. If I was buying from scratch then there would definately be some differences. Like more compression and different cam.
We had Jack at MPD race detail an impeller that will go right in our pump. We are taking a B/C out and putting in a AA. The impeller selection thread guys are all over the place with HP ratings and impeller sizes. I told Jack 1,300 HP and an equal amount of torque. He came up with the impeller and I trust him 200%
We have a 522 BBC Merlin III block with billet caps. Callies Crank and Rods. JE blower pistons 7.7:1 Edelbrock heads. Hydraulic roller turbo cam but running Morel solid rollers on it. Dart intake 16 160 lb bosch blue top injectors. FAST XFI FAST XIM 8 LS2 coils FAST Crank trigger. Enderle 990 pump belt driven. System 1 fuel filter will home make fuel rails from 1"id alum tubing. all #10 hose. Dual aeromotive EFI return regulators. Billet throttle body. Mark Unchained's stainless headers and a pair of 64mm T6 Garrett turbos. CO2 wastegates and FAST 4 step control.
That is about it. Plan to get started pretty soon. We will not have the power of Unchained or Hass. But do intend to outrun them. :D
I'm famous !
I need your shop stuff " just laying around " Geezz i have dust bunnies in my shop lol
New here
Wow. NICE list of parts. Isn't -10 line and 1" ID tubing usually for WATER DISTRIBUTION??? :D
I know you already have the ECM stuff, but I have been pouring over the specs of the new Holley Dominator ECU. Holley is not known (Yet) to be in the main-stream of top ECM stuff. But this ECM is $1600 or so and controls EVERYTHING. You just buy harnesses as you need them. DIS with 24x or 58x wheels, including a stand-alone wheel that bolts to the balancer! They seem to really be in the fight these days. I especially like (mainly for street-use) the dual-channel O2 section for dual sensors. Nice to know BOTH banks can be watched. I downloaded the software already and the screens look real nice. Appears to be real nice stuff. I mentioned this in the "other" thread.
:D:p
alright! now yall put a date and place on this race, say broken bow memorial day:)bulb:D i'll race both boats to half track:p
smart...:)devil
that'll just be light work for the orange boat... your only challenge will be that black flat with the asian lookin guy driving. and when you smoke 'em, maybe the guys in that shop will look at the orange boat a little differently....:D
what year, and with what???
bp, im jus messin with em:Di think ron means lake racing,and i might be able to keep with em for maybe 400ft since ill be so much lighter and big boost as well if we left from a stop, after that i'll jus get embarrassed:p ive gotta lil 300lb 1985 16ft mantra tunnel with a blowthru 325cube lsturb engine, be around 800hp/tq.
tom, it would be impossible to come on this forum for any length of time and NOT know what you theoretically have. you've got like 9000 posts talkin about it. this is right up there with rcl's gn boat - the project that never get's done, runs into every bump in the road, or make's it's own bumps to trip over.
on the other hand, ron bought a boat less than a year ago, completely re-rigged it, and it's badass the way it was. i have no doubt his deal will be done before spring, and he'll proceed smartly with it.
New here
lol ron's boat is a ton different than "the way it wassss" when he got it:D only bump in my road is lack of funds due to divorce, my engine is ready to run as is my pump, once the hull interior is done, it goes in, boat goes to the water.the boat that'll never get done, that's funny since i've built myself 6 dragboats in the last decade:p guess im the only guy who took 2 winters to build 1:D
New here
my welder has my frt mounts tiggin em up, then i jus gta get a starter:D
Wow. You're getting CLOSE!
Can you use standard mini starter for an LS? Or will your bellhousing/coupler config not allow something that simple?
jus the normal ole stock mini starter, weighs like 4-5lbs, its lite. i built a plate for the back, frt pad mounts for the frt.
New here
Sounds like the easiest part of your build.:)
I made a fuel rail for a 4 cylinder from some tubing....holy crap that was annoying!
When I was building my Procharged 502 I wanted big boy fuel rails. Kinsler had what I was looking for and super cheap. I got 2, 15" rails cut. the biggest cost for mine was that I had them tap in -12 o-ring flange in the ends because I didn't have the tap for it and i didn't want to run NPT. I drilled the fuel injector holes and rail mount holes and called it a day! if you just got their -12 rail stock its super cheap. i want to say like 15-20 bucks a foot or something like that. (I can't remember exactly, but I was surprised at how cheap it was) for me it was well worth the money to cut down on the labor. plus its pretty much the exact diameter you wanted .947 i think
if you do it from tubing I would think you would need to weld bosses on each part of the tube for the injectors. with the kinsler rails you have the material on the bottom and you just drill them with a 14mm bit, put a little step in it and fab up some mounting for the rails. tap the ends with whatever you want and your done!
when I built the 4 cylinder fuel rail from tubing, after every weld I had to pressure test, recheck for straightness...it took forever! If I could have bought something I would have...way easier and less time consuming...well worth the money in my opinion.
heres a pictures of the difference between the -6 and -12 rails
Andrew
Cool.
I planned on machining a radius in some square stock to weld on the tube for the injectors.
I looked for some super rail extrusion but couldnt find what I really wanted. I'll take a look at Kinsler.
1 - 20 of 858 Posts
