I have skied off the eyes on the transom (the trailer tie downs) and I have had no problem thus far, Except that it is harder to cut when the boat end of the rope is really low. I would never tow a tube using them uless it was some wussy in the tube. I dont know about you, but when people ride in a tube behind my boat I prefer they climb out of the water bug eyed, hard breathing and shaky in the knees. All that slacking and jerking spells great big hole in boat to me. Havent ever wakeboarded beind a jet boat, seems pointless to me, you have to have one of those deep draft, water chopping yuppie boats.Is it ok to hook up to the hooks on the transom, I go about 250 lbs and I wounder if it will tear up my boat.The wood is good and I dont have any stress cracks back there.
you might want to note that your looking for a ski barI have skied off the eyes on the transom (the trailer tie downs) and I have had no problem thus far, Except that it is harder to cut when the boat end of the rope is really low. I would never tow a tube using them uless it was some wussy in the tube. I dont know about you, but when people ride in a tube behind my boat I prefer they climb out of the water bug eyed, hard breathing and shaky in the knees. All that slacking and jerking spells great big hole in boat to me. Havent ever wakeboarded beind a jet boat, seems pointless to me, you have to have one of those deep draft, water chopping yuppie boats.
You might want to recall that I am looking for a DIFFERENT ski tow, The one I am using just doesnt fit the intake manifold I have, and am having to use long bolts, which have bent.you might want to note that your looking for a ski bar
No, I am using the one in front of that contraption and both of the rods that bolted to the intake are to short, and from what rex told me its probably not a good idea on the olds motor anyway, So tom hooked it up with one that only bolts to the flywheel cover, and I am planning on get my headers re-chromed during this cold spell, so a powdercoat on the tow is no big deal.what was that bar he had in the back ground it looked like it surounded the hole carb is was a ugly contraption. the one in the pic looked beat, why not just cut off the rod your having a problem with cut a new one to the right size weld it in. its on the cheap get it powder coated and be done with it. you did say the other three fit right?
Actually I would think that towing a tuber would be harder on a ski eye(or at least it is in my boat) because you have weted area drag pulling a tuber. I know on my boat I can pull two tubers and I have to be careful about how hard to get them up on plane as the ski eye will bow into the engine hatch. I can pull two skiers up as hard as they want and my ski eye is rock solid. The stoutest design I would think would be a stringer mount set up. Way back when a neighbor of ours tried to pull up 14 skiers behind an old sanger (of which 7 got up). Most skiers ive ever seen pulled up. My .02I've pulled people on tubes using the transom eyes.... With one of those deals that hooks to both sides & has that pulley thing in the middle that you attach the tow rope to. Probably not quite the same amount of stress compared to pulling an adult on skis I guess.... Although, my transom has been replaced just a few years ago, its a fresh 1 1/2" thick of wood back there so that may make a difference.
I've got an actual ski tow, but I've never used it as I've never tied in the brace that bolts to the transom. (Its on the back of the boat, not the engine, you can see it in my sig pic) If you've got one that bolts to the engine, you may want to go ahead & use that...
I bought it from a shop out here in san diego (JP marine) used. It has top and bottom engine block mounts. I have pulled boats with it before. If your looking for a setup like that, post in parts spam or get some boat shop #'s. Alot cheaper to find a used one. I paid around $100 bucks. I have since replaced the bottom of the cover as well.that is one trick set up nice clean polished. i may not like most fords but i would have to say that even a chevy guy can like something that nice. did you build or buy that ski poll set up? my uncle runs a 455 and his bends all the time but it is just bolted to the stringers. nothign giving support to the top other than the glass when it bends that far
