Need some help or advice, please.
I have a Competitive Trailer, and I need to replace the inside fender walls, or whatever they're called.
I pulled one of the old ones to use as a pattern, but it fell apart in my hands when I removed it. I took a piece of heavy cardboard, mocked it up, and traced out the inside pattern, and enough flange area for the fasteners. I'm assuming that's 3/4 Marine or Outdoor use plywood that was there before.
The old ones were covered in Black Astro Turf, and I don't know if you can get that stuff anymore. Might have to use some type of carpet to replace it if I cant find the turf, (I liked the turf).
Fasteners...Where do you get them at ? These kind of look like a 5/16 carriage bolt, but the head is flat, and is larger, and has 2 holes for screws to keep it from turning once mounted.
I know you guys have done this job before, so any advice to do it the correct way, or easier or better, would be greatly appreciated.
I didn't include any pictures, but if you need them, say the word and I'll go take some.
Thank you for your time,
Mod
Mod
