Also my trailor has a bunch of sh$% weilded to it and i want to clean it up so id like to see some pics of trailors to get some ideas....Grasias
Make sure they fit well between the strakes, they push up evenly on the hull, and insure that it will be impossible for the boat to contact anything on the trailer except the bunks, rollers, and bow stop while towinghandMy first question is how do you make sure your boat fits well on the trailor my bunks look to be the right ones but one needs to be raised up if the front to fit boat but how the hell do i make sure with the boat on it.If its off you dont know were to fix . i hear so guys talk about the sides of the boat warping if its not sittin right .Whats the trick ...
Also my trailor has a bunch of sh$% weilded to it and i want to clean it up so id like to see some pics of trailors to get some ideas....Grasias![]()
This may be the "right way" but too ambitious IMHO...OK heres how you do it . Take the boat off the trailer and cut off every thing you dont want and all the bunk mounts . Get 3 1/2 X 3/16 flat and cut 10 pcs. 9 inches long. Drill two holes 1/4 inch holes 1/2 inch from the sides and 3/4 inch from the end . Measure back off the same end 3 inches and bend 90 degrees . Now you have now you have 10 bunk mounts . At this point you should have your new wood and carpet as well. Roll the trailer back under the boat and level it side to side front to back " hopefully its not twisted" . Using four jack stands place them as close to the spring mounts as possible, this will help simulate the true weighted condition of the trailer. Set the boat down lightly using blocks under the keel at the front cross member and back cross member and level it side to side under the chines . At this point its just cosmetics on how high or low you want it to sit on the trailer . Once that is done apply full weight of the boat to the trailer . Now cut a foot long piece of lumber you plan on using for the bunks and rap them with the carpet you plan on using . If you are doing this by yourself then I suggest screwing each bunk mount to the 1 foot piece as you go "Just makes it easier " . Go under the trailer and position the bunk and mount assembly close to but not touching the strake 1/4 to 1/2 inch should be fine. Reach around and mark the angle that the mount is to be cut and mark the location that the mount is to be welded to the cross member. Label the mount with its location . Unscrew that mount , screw on a new mount and move on . After all mounts and locations have been marked , compare mount angles and locations from side to side . If boats straight and trailer is straight than every thing should be reasonably close. If for some reason one mount is considerably taller or its position on the cross member is considerably different from one side to the next than double check it .If everything check out OK than its all down hill from here . Cut and weld as necessary. By starting from scratch you KNOW its going to be right. If you decide to save any thing it should only be the rear four mounts.
coolsorrey about that bud it's to cold for me up in bc to take the boat off but i can send a bunch of pics around the trailer
