1 - 20 of 36 Posts
Newbie to the forum with what may be an ignorant question..
Can anyone steer me in the direction that I might locate a transom housing that would work with this setup, or am I gonna need to just fab something to fit ? I'm certainly no stranger to a project or two, but to be honest as far as Jets are concerned I've done a whole lot more burning gas in them than working on pump setup...
I'm just now in the "mock up" stages of this 18 Biesemeyer with a Berkeley 12jr and I certanly dont mind fabbing something up nice to fill the void from the bowl to the transom, but also don't wanna spend a fairly decent amount of time cutting, fitting, welding, ect..ect.. for something I can pick up fairly resonable if possible ?
I can pull any measurements needed, and can get the angles as well.. I have a couple of what I would call standard Berkeley transom housings but they are quite a bit different.. The pump is setback as far as you can set it without cutting any of the lower edge of the transom so the ones I have are not only to short but are definitely not made for a flat transom either... Also as you can see by the silocone line in one of the pics, the one that was on this boat at some point was tappered at the bottom and not as square the other two housings that I have... Also what I'm calling the "standard ones I have" for lack of better terms, hang down below the bottom of the boat on the lower corners of the housing... (Mount holes are different too)
Anyways any direction that I might get to someone that may have something off the shelf that might work, ect... please fire away.... And ifnot I guess I'll start dragging out tools & material...
** And on a side note I'm assuming the cleanout is gonna be a bit of a pain to get to, so any wise idears there are more than welcome **
Thanks !!!
Mine is setup very similar. It has essentially, a custom "deep" transom housing fabricated by cutting the flange from the face and welding in a rectangular ring to fill that gap, which puts the cleanout (at least on a JC pump) inside the housing and renders it useless. Kind of a PITA, but it is what it is I guess.
My transom is a bit taller though, so not sure what to tell you about the bottom.
(77marlin..). Yeah what you describe as far as cutting the transom housing is pretty much what I've had in mind that I'll probably have to do.. I actually have a housing that's been cut on some already and if that's indeed what I have to do then I'll probably just use the "round ring part" and fab from there to the transom because the square part that meets up against the transom fits very poorly on the bottom.. And yeah feared the clean out issues..
Do you have any pics of your pump that you can post ?
Welcome to the boards.....bust out the tools and start fab'n bro. haha That Bieser hull bottom looks bitchen. That definitely looks like a one off deal especially with a recess cup for the hand hole clean out access. Most peeps use 1/4" alum plate for the main transom plate to suction housing seal area. Peeps have been pretty creative with fabricating a boxed alum. recess niche behind the hole to allow access from outside the boat. Yours looks like it may be a little tight by the height of the transom, you may have to do some shaving there. Nothing like the feeling of hacking away on the structural integrity of your boat. haha There's quite a few pics in various threads to see for examples but if you're a experienced fabricator you will be able to figure out what you need to do for your specific conditions. On a setback application, I prefer a 2 piece plate system. The main larger plate basically permanently (3m 5200 silicone) seals the transom and reduces the large transom opening to a reasonable size necessary for easy removal of the suction housing ( for general maint./changes/repairs etc.) to accept a smaller plate that seals to the shape of the suction housing leaving a max gap of 1/16" between edge of plate and casting surface. I like a little silicone to pass thru and then seal from inside of hull as well. With good power these things can move quite a bit breaking the seal and causing pesky leaks down the road. I use 3m 4200 silicone for the plate to plate seals and suction seal. It's tough shit but allows for removal with careful effort. Your secondary plate may include the fabricated box notch delio but I'm not seeing clearly how that will as I type. I guess it depends on if your secondary plate reaches between the flanges on the intake adapter. If you fill between the I.A. flanges with a welded or epoxied in place block (could include transom drains as well prolly 1/2" pipe plug size) you should be able to use a 2 piece system because the bottom portion of the plate will be wide enough for a vertical/forward removal once the seal is relieved. If you are going to be removing the I.A. for machining for a shoe and ride plate (making assumption here) then that would be a perfect time to weld in the blocks between the flanges. That also makes for a better, cleaner, sealing of the transom plates in my opinion. I hope this helps. Good luck, have fun and getter done. Lookin forward to seeing how you address this.
My float is at the lake ...and I'm not ...lol. I can get you some pics this weekend if that helps.
FWIW, I have learned to embrace doing my "cleanout" from the bottom side. I have had to limp back to the boat launch and load it back on the trailer so I could get at it from the bottom, but only twice have I had to do that.
Jetjunky: Thanks for the detailed info.. I'm with you up till: [QUOTE I guess it depends on if your secondary plate reaches between the flanges on the intake adapter. If you fill between the I.A. flanges with a welded or epoxied in place block (could include transom drains as well prolly 1/2" pipe plug size) you should be able to use a 2 piece system because the bottom portion of the plate will be wide enough for a vertical/forward removal once the seal is relieved. If you are going to be removing the I.A. for machining for a shoe and ride plate (making assumption here) then that would be a perfect time to weld in the blocks between the flanges. That also makes for a better, cleaner, sealing of the transom plates in my opinion.[/QUOTE]
I can shoot some better pics I'd need be... I have a shoe that fits it nicely but no ride plate, and to be honest wasn't sure if I needed a ride plate or not ? Ifso then yeah I thought this would be a good time to incorporate one.. Feel free to post any pics, talk to me like a 3rd grader, just whatever.. Haha!!
Thanks for the welcome, and yeah I'm not familiar with how many of these hulls were built, although I seen a pic of a nice orange & white one a few days ago while searching around.. Although it's been a good while, I grew up around jets & v-drives and had never personally seen a Biesemeyer that wasn't a v-drive until I ended up with two ;-).. The other hull is not a "modified v or tunnel" whatever you would wanna call it, just a standard v
I'm also not completely against setting the pump back a little further and obviously filling the hull itself in order to get the clean out all the way out of the hull, and if there are any other advantages to it as far as handling goes.., also I'm just getting into this so I've not even measured how far I can go back as far as the rear of the engine & hull clearance goes.. A couple extra inches of interior room sure wouldn't be bad to have.. I'm gonna try to squeeze a small bench in the rear of some sort for the kiddo's...
However that being said I'm near clueless on how these hulls handle with what, how much setback they like, ect.. ect.. So just tossing around some idea's
I guess the foremost question at this point in the game is.. what are your intended plans for the boat? What kind of power and speed are you planning for it? If it already has a shoe then adding a ride plate should be easy meaning...machine 1/4" recess in shoe for ride plate, drill and tap holes to mount. The ride plates just extends the keel running surface a little further back and gives you more tuning capabilities and ride stability. ( helps with porpoise issues, makes the boat act like a little bigger boat etc.) I would caution against moving the I.A. back just yet. It's a lot of work, gets pricey and can degrade the hulls structural integrity some by weakening the transom if you go "all out" so to speak. Depending on your plans/goals for the boats performance a set back pump doesn't necessarily mean you will gain cockpit space. To maintain hull balance the faster you want to go the further forward the motor needs to be. As I understand it, generally speaking the further back the pump is the higher the mph, the further forward (std./stock location) the quicker (e.t.) the boat will go. It might be a good idea to take a momentary step back and establish a complete evaluation of your intended plans for the boat, budget etc. and then research and gain as much knowledge as to how to most effectively achieve your desired goals both performance and budget wise. Since that particular hull (As far as I know, which accounts for little) doesn't have a great deal of obvious history, (easily/readily obtained info.) You may want to search around for the guidance of someone who has a great deal of knowledge and experience in general in hull set up (i.e. Jack Mc Clure @ MPD, Chris at B-1 etc. (Chris worked for Jack, was a great student and has a very successful record in his own endeavor now) and if possible someone with a proven history (? Jack @ MPD? He's older (history) and a no BS kind of guy) in setting that style of hull up because it sure as chit ain't me. lol We have just about come to the end of any usefulness I have. I'll see what I can do for pics. I hope this helps.
PS- do you know the history of that particular hull? who built it, did the shoe mods, set the intake? hull bottom mods if any? keel work if any? That could be very helpful if you can get ligit info. Hearsay, not so much.
It will be very helpful to get as may detailed, quality pics of the hull bottom, (keel and intake transition, strakes, chines etc.) and have as many measurements and angles as possible to assist in discussing your hull with the guru's. One important and specific angle that you could quickly obtain is the relationship of the intake adapter to keel angle as installed currently. One quick and easy way is to set the hull's keel level with a good level, next remove suction housing from I.A., clean surface of I.A. from any foreign material and set digital (calibrated) angle finder on I.A. mating flange surface to obtain intakes installed angle. Oh, and get the cast model #s off the I.A. too so you know who's/what your working with specifically. This info. will be useful whatever your plans for the boat.
Discussion Starter #14
I knew that question was coming.. That can be a broad one because I've not had to many projects that didn't morph into more.. Haha!!! I say that because I've not had this thing but a few days so just now really getting into planning stages...
That being said I've got a couple ways that I could go with power as far as BBC or SBC.. With both having advantages & disadvantages without writing a story book, and that's 99% financial & time related as usual.. So for now I am strongly considering putting a mild SBC in it (for now) because I have a complete running one pretty much minus exhaust sitting here in the shop.. But also have most everything but a good crank, some basic machine work and "nick nacks" to put together a very nice & rather healthy SBC that could easily be swapped over whenever that time came... I also have the BBC option but I'm kinda leaning towards the "progressive" SBC option right now...
So in another attempt to answer that for now I'm not looking for that last few MPH.. My intentions as they stand are for a fair weather family cruiser so to say..
As for my setting the pump back further comment it was as much as anything coming from the side of a couple inches to better access the clean out.. And if something was gained from the effort then great, but just really more of an idea to toss out.. And Definetly not something I would just jump into blindfold from a research & having my ducks in a row standpoint by any means.. This is a personal project so as with anything else I've ever built for myself, budget is Always a big factor.. That doesn't mean slap a bunch of junk together for me, I just have to be as resourceful as possible..
I have a fairly well equipped shop and have no issues with fabrication.. Any glass work would be done here in house with combinations of bi-ax, and or carbon (if need be) and all epoxy resin.. I keep allot of different projects going from customer work to personal junk.. As far as boats goes, I recently finished some work on a good customer & friends 20 Cole, a 399 Skater V, and an ongoing 15 Allison project that I'd like to be giving some attention also.. I say all that to attempt to say that other than it being what feels like 125 degrees in here, and hardly ever having much time or money for my own personal projects the labor is not an issue.. Haha !!!!
Thanks so much for All the suggestions & wisdom so far !!! I know this stuff takes time so it's well appreciated and will be well soaked in.. ;-)
Here's a couple shots of the shoe along with what I would call the loader.. The numbers on the what I'm assuming is the intake adapter are H-2780, and it's Berkeley as well.. The numbers on what I would calm the intake housing are H-1727, also Berkely... The Model number is 12JR-A-SS
Looks like the shoe is already machined for a ride plate if I understood correctly...
I unfortunately have little to no real solid history on this setup, but I will say that I'm honored to have rescued it up !! My old man & I both have admired the old Biesemeyers for as long as I can remember so it's a cool little project for me..
Discussion Starter #17
I'm looking at this stuff on a phone right now so pics are a little tricky, but I'm assuming by those that your clean out is mostly inside , but appears to be partly sticking out ? Possibly a stupid question, but do you have access to it ?
That model # means you have a Berkley Race Pump, the A is an A impeller, the SS stainless steel impeller...they also came with the Aquament Shaft.
The loader you show looks like the old GTH stuff...I like your boat :))THumbsUp
Discussion Starter #19
Thanks, yeah I think I ended up with some pretty good stuff.. The machining is nice on them... As I said I have always admired the Biesemeyer's so when this rig pretty much stumbled upon me, it was just a good fit for me so I'm looking forward to playing around in the tool box and seeing where it leads
I took a couple pics. of my transom plates, their off the boat, but you will see what I'm talking about by their shape etc. I tried to load them on my computer but it didn't work. I've been having trouble with thaat for a while now and haven't figured it out yet. I can text them to you if you like or you can wait till I get my upload issue figured out and then I can link them here. If you want to pm me with a contact # I will text them to you.
One question of interest I have about your hull is how much lower is your keel depth than the outer drop chines? I wonder how that compares to the keel depth difference than some of the top performing current tunnel hulls running about out there? It appears that hull has a flat keel as well and it seems there has been significant improvements/progress made in efficient pump loading with a flat keel set up in recent years as compared to when that hull was built and run. Guessing by the loader hardware that boat hasn't been run in quite a few years. That loader piece is one unusual looking piece. Does it bolt to/thru the I.A. as it appears? Where does the leading edge sit in relation to the bottom of the boat when installed? Is the leading edge flush, hang below, or retracted above the keel line of the hull? Just curious. It would be cool to see more pics. of the entire boat. Do you plan to flip it over any time here while your working on it? It would be cool to see some good photos of the bottom too, I'm sure it has a lot of interesting detail in it. There was a Biesmeyer hull running in the comp jet circle racing class some years ago but I'm not sure which model it was, like yours or the other standard v bottom. I'm guessing the latter one. Maybe somebody familiar with that specifically will chime in here or even Nick Valore (screen name cj222 here on the boards) since he was the one shoeing it. Curiosity.
1 - 20 of 36 Posts
