1 - 20 of 38 Posts
anybody got any pics with puke tanks transom mounted? i'm hurting for a place to put my tank and i've herd some put it on the transom, just wonder how they did it and what it looked like. i can't find any place solid behind the motor to mount it. i had it mounted the the back bearing plate on my blown 475.appreciate any help fellas:)devil
my old boat, had two on the sides towards the back transom.
that's a good lookin set-up man:)devil i've only got 1 big tank with 2 big k/n filters on it and inlet on both sides. if i'd thought ahead i would've sold it and bought me 2 small 1's that attach to the cover:)sphss
lol, right.....
What happened to the bracket situation, Tom?
There is a yellow jet I have seen pictures of that had a puke tank mounted the way you describe...
So yours kinda looks like this huh? i know, its a sweeeet a$$ drawing!!
yep, that looks about like it, but you forgot the drain:p:D
kenny, i screwed up enough plate this weekend trying to do what we talked about.
B.A.M aka "Black Azz Mike
Ill post mine ;)
here ya go;)
jetboataholic
What is a puke tank for?:)eh:)
To catch oil. When you spin high rpm's the oil has a tendancy to puke out of the breathers. This happens alot in boats. Cars dont usually do it because they dont drive down the street @ 5-6k rpms.
Damn Tom If I lived closer could have made one about 20 min. :D
Mike where did you get that tank at with the bracket already welded on?
Discussion Starter #18
i built a nice looking transom plate last nite, shaped and polished it out. its actually gonna look ok, so i'm goin forward with drilling 2 new holes in the boat:)st:)st
george, i should've just sent you the tank :p had you build something but transom mounted will look alright, i'm just not used to seeing it but it'll dame sure keep the bilge clean this way:)devil
jetboataholic
Should I have one? My boat will only turn 4300 RPM max. Thanks.
1 - 20 of 38 Posts
