1 - 20 of 21 Posts
ERECT MEMBER
does anyone leave their truck in havasu year round, and use it maybe 2 times a month? Do you have any problems with the seals and rubber drying out? I would think it is the same as the boat but just thought I would get some input. It would be in a carport not a garage.
Thanx
G
Thanx
For the most part, my Lightning has been garaged at my house in BHC since 06. No problems.
Former HB visitor
My F-350 stays in Havasu in a garage. I don't think you have to worry about seals if its used every couple weeks. My truck has been out for a year now. No problems. I have friends that are snowbirds that leave thier truck from May to October at Havasu and the seals did dry up. I believe regular use is the key.
Just my unscientific opinion.
ERECT MEMBER
Discussion Starter · #4 ·
I am afraid of messing up the truck, I would use it at least once a month if not more. I would like to leave it and drive the wifes more economical car since I don't need the truck at home.
Stihl Kicking
Its not a truck but we keep a 4 wheel drive astro van at the havi house year round. We don't even keep it in the garage, never had a problem.
Former HB visitor
Get some good tire covers and a good cover for the truck. I did that for a while and it was not a problem. I worried about the truck but it was fine.
Only problem we have is the new gas going bad. We never fill the truck up anymore, and add some fresh fuel every month in the summer months.
I have been keeping my truck there for years(9) I usually bring it home in the winter to do winter yard work and stuff. I have only had an axle seal leak but not sure the storage time really had anything to do with it.
I'm baaaaack...
We kept our Ram 3500 there for a couple of yers now, no issues.
The only problem that I have had is with the battery in my Jeep. Two years in a row it has had to be replaced after being gone for about 3-4 months. All the other batteries have been fine just the Optima in the Jeep...
Steve
ERECT MEMBER
Discussion Starter · #13 ·
Steve
ya I was gonna ad a battery tender too it.
It sounds like I should not have an issue, its a four year old truck and I don't want to ruin it. The only reason I keep it is to pull the boat in and out of the water. We never drive it when we are in CA. so I figure why not leave it in AZ. just don't wanna hurt it, I don't plan on ever replacing the truck.
The HMFIC
is the truck in question a diesel????? you should not leave diesels sitting for extended periods of time its not the seals you have to worry about in a diesel its the turbo system the fins can rust and there is no room for error in the turbo.
I have a Suburban out there, the problems I have have had were the rubber valve stems dry rotting, about 3 or 4of them. The window seals are brittle, But it starts up and goes!
ERECT MEMBER
Discussion Starter · #16 ·
I can see that being a problem If I only went to the river twice a year but since we go at least every other weekend I don't think this is an issue.;) I also don't see moisture being a huge issue in the Mohave dessert:D
"Try it Now!"
You guys are ballers! The trucks you leave at the river for "RIVER TRUCKS" are nicer than most of us own for our primary vehicles! I'm jealous!
Lil' Hellyun
I have left my diesel Excursion out there year round for nearly 4 years with no problems....we do the same thing and drive it at least twice a month....good luck.
I take it you dont visit in the winter much. Its freakin cold!!!!:D
I would find a trusted neighbor to go over once a week and fire it up, If your not going up for a month.
I leave my Tahoe in the garage all winter long due to my snowbird being there. I just un hook the battery and put some gas treatment in the tank. Haven't had a problem yet. :)sphss
1 - 20 of 21 Posts
