I've posted a few previous posts about "Mellow Yellow" but figured I should start a new thread here. Bought for cheap; bare hull & I don't know anything about it other than home built in the 60's out of mahogany that was glassed over and was powered by a big block Ford. I've got a soft spot for saving things and already found a Casale box for it, planning on a blown 6L LS just for the look and to make it as fast as it could safely handle.
In another post I mentioned some blistering on the top surfaces in places and was planning on using epoxy/cloth to build it back up (after proper prep).
The boat has now been in my heated shop for a month with good airflow and has had a chance to dry out...
I decided (was motivated) to get out in the shop and start going over areas in the bilge etc that I know were going to need some TLC tonight.
So - I saw a little water weeping out of a low hole in one of the stringers; not good.
Sure enough, now that things are "drying out" I can poke thru the lower areas of the stringers in a few places when I reach thru the open holes - ok; rotten; I can deal with that.
Then I stepped on a section of floor that felt soft and heard something like a liquid squish sound (WTF?) - drilled an 1/8" hole thru the glass (inside the boat) and about half a cup of water came out; after drilling a bunch more holes, the separation/gap seems to be confined to about a 12x12" area...
Now I'm a little frazzled (pissed I paid 500 bux for it & the trailer). After spending another hour going over everything I can see with a small hammer and sharp pick, I found a 1/2" soft spot about 2 feet under her nose and punched right thru the hull, but hit something very solid about 1/2" above an air gap - looking inside I think it's a metal plate the builder used to stitch a seam together with. Assuming the fiberglass separated from the mahogany wood in that area? So - I'm a sucker for punishment; love a challenge (and kinda hate myself, lol) plus I can't forget that someone spent a lot of time and love building this damn thing in their garage at one point....
The stringers need to be replaced, the water logged area of the floor has to be cut open to the wood and dried out/epoxied/clothed back together and I'm guessing the hull flipped and the glass cut off the entire front area where it has separated, the wod replaced if rotten, then everything epoxied/clothed back together? Has anyone ever got into this kinda restoration, or can point me to a forum/place where anyone else has?
