Is the Procharger's a turbo that they take the ex impeller off and put a gear drive ( I think about 3 x ) on then belt drive it ? what ratio do you run on the belt ? overall ratio of both ? could you convert a turbo off of a cummins or caterpiller ? just thinking ,,, I have access to a holset turbo,,
the last is how many size's of the procharger's do they make ? the centrifugal take's less Hp to turn(than root's) even with all the overdrive ?
thank's in advance.............Eric
hand
