1 - 20 of 29 Posts
Take that carb off and lets have a look inside...:D
Nice work as usual.:)devil
Needs a trucker girl air cleaner.........
Jim
Cantard
kinda sorta had an accident with the plenum and it ended up facing the other way on this thing.:D Easy mistake when your inspecting the inside of an intake I guess. lol
It's what we do
Checkout the idle mixture screws too
Cantard
Discussion Starter #17
I'm guessin..it's hydro-bound ...but wtf do I know...:)grn
:)devil 280 cubes of raw power. lol
Engine sits at such an angle that carb shims would screw up the plenum and the thermostat housing would be asking for an air lock. Water is fed into the block where a water pump would go and exits the intake at the distributor. Basicly cut the plenum off and turned everything 180....milled the housing off and welded in the water ports.
Village Idiot
I didn't even notice that till you said that. Then again, if it doesn't have stack injectors I don't even know what I am looking at.:D
Paul
1 - 20 of 29 Posts
