1 - 20 of 20 Posts
Member
brendella
That boat lives around the corner from me. the guy did a half ass job restoring it and then tried to cover his mistakes with paint. It is a bad ass hull for someone who would like to restore it. but not for $10,000
@@@@@1977 brendella v-hull speed [email protected]@@@@ - $10000 (bf)
Reply to:see below
Date: 2009-05-31, 8:30PM PDT
custom pickle fork, flat bottom,casale v-drive, v-8 very rare model. custom paint matching trailer ,tag up to date
too fast for family.perfect for the lake summer is coming $10000, obo or trade ????? (661) 978-5499 Ask for Pete.
  • it's NOT ok to contact this poster with services or other commercial interests
If it is anything like the Brendella v-drive tunnel that was around these parts 8 or 10 years ago it is probably an ill-handling nightmare. Jet hydros and v-drive tunnel hulls are "rare" for a reason.
My Dad sunk his V-Drive Daytona in Mission Bay. He said it would start walking on him on the top end. Bob Leach gave him a jet instead.
wmorton that is so rad though dude..im 49 yrs old and love that look with the wing..
I agree the wing on that tunnel looks bitchen, but it probably only added to the inherent handling problems of the rig. It likely would have worked better with a front wing.
V-drive tunnels.........yet another bad idea best left in the annals of hot boat history.;)
He tried the wing to aluviate the problem of the ill handling. From what I was told there were only three of these boats at the time. After of sank, the boat sat at the shop for a long time. I wonder who ended up with this hull.
I bet the concept would work, but the idea would need a lot of R and D.
Absolutely, that's the concept to make it like a hydro where only half the prop is in the water. I know the prop works on tunnel hulls in the radio controlled boats, but the prop is way past the transom. That might be the answer to the problem. I have seen a arneson surface drive on a tunnel, but never found out how it worked. I did see the same surface drive from that boat in the parts spam section, so kinda doubt it. It's hard to spend money on R & D when your an enthusiast. Next time the economy gets an upswing we need to get someone to come up with the answer.
Under yo mommas bed
pardon my ignorance, but wouldnt a tunnel design try to pull the prop up out of the water as well? :)sphss
Shouldn't be any different than an O/B tunnel if set up right. O/B tunnels work very well. Instead of trying to work with a wing I would play with the drive angle.:)devil
I'm no engineer, but I think it is different than an outboard because you have a balance point under the boat. On an outboard the lift is planting the tail of the boat so the engine can "dig" deeper. From the one v-drive tunnel that I saw make plenty of passes, chine walking was the major problem. As it packed air and got lift it teetered on that prop as a balance point and became very erratic. With a hydro, the forward propulsion blows the tail and plants the sponsons. With one of these if you blow the tail, you blow over!:)hand Tons of downforce on the front with big horsepower to plow through water might stabilize one, but why have a tunnel that runs wet like that? Kind of defeats the whole idea. These things are a nightmare IMNSHO.
waiting sucks
Someone on the boards has a daytona v-drive. I think his name is unchained? looks to run fairly well IMO. There are a couple vids on youtube.
The boats being referred to here (rare Daytona w/o centerpod & Brendella) are essentially CATAMARAN style hulls and have not been very successful as V-drives. The few Daytona's, Cougar's and that boat Eddie Hill has work quite well because they have CENTER PODS. I've owned the black 21' Daytona v-drive that Smitty now has and it has run up into the 130's. I currently own a 19' Cougar with a mild blown BBC that should run 110+. Both of these boats are incredibly stable at speed. Jocko
Jockorace,
Excellent point. I have seen a very hard running Cougar v-drive and it is night and day compared to one of these Brendellas. The Centerpod makes a huge difference in stability.
That looks like the boat that I bought from Eliminator in I think 1978!
When I got the boat is had the name Breaking Wind down the center of the deck.
The v-drive had a 1/2" mounting plate and was cut for big gears.
I put a mild 427 in it and it did not work well. I ended up parting it out and the guy that bought the hull was going to put a outboard on it.
That was it, "breaking wind." The internet is truly amazing. I came across other pictures if you would like to look.
1 - 20 of 20 Posts
