1 - 7 of 7 Posts
Need some pics of guys running vac pumps. I want to run a small tank directly plumb to the valvecover and then to the star pump and then to a larger tank. Probally overkill but just curious if anyone is running this same set-up. Kinda want to keep everything mounted to the motor for easy swap.
Thanks
B Broyles
Discussion Starter · #3 ·
ideas???? and yes it is overkill.... i agree
:) probally right .... not busy enough at work i guess.. here are some pics if anyone has a good idea....small tank plumb to the valvecover and then to the pump then to the large tank.... do i have to use the large tank?
That tank is huge. You plan on pumping the thing dry? Im not a big fan of putting the tank in front of the header, but that looks ok if thats where you want it. I mounted mine on the rear of the engine to the head,but im still not certian if i like it there either. No pics right now as I have everything out of the boat for Powder coating.
Discussion Starter · #5 ·
Thanks
Don't want to have to empty it as often with just the small tank but i agree about the header being close. I am thinking stringer mount low and out of the way
Bubba
I mounted mine to the pump support
bracket, it's low but you can get to
it to empty it.
Call me if I can help. The first KDBA
race is June the 7th & 8th, hope to
see you, your Dad and Gordon there,
maybe we can hook up and travel
together.
Paul
Discussion Starter · #7 ·
Vac Tank
Thanks Paul,,,, I think My dad and I are planning on making the trip but i am not sure about gordon. We are working on my new ride now so if all goes well we will contact you a couple of weeks before the first KDBA race.
BB
1 - 7 of 7 Posts
