1 - 12 of 12 Posts
I recently bought a 396 sbc stroker from a buddy. He had it built put it in a drag car made a few passes with it and lost interest.
I am am in the process of freshing it up, changing the cam and a few other things so I can put it in my aluminum jetboat. He said it always wanted to blow out intake gaskets so he put breathers in the valve covers with lines running to the exhaust to remove the pressure. I don't want to do this on a boat.
What are my options, no pcv, will a catch can work? Or do I need to get a vacuum pump?
I'm not an engine builder, but here are my $.02. I've never seen an actual intake gasket (gasket between head and manifold) "blow out", but I have seen the rubber or cork gasket piece between the valley blow out and cause an oil leak. Because of that, I never use the provided valley piece and just use black RTV. If it's truly blowing the gasket out between the heads then there is something else going on. You did mention that it was a fresh motor with only a few passes on it so maybe the rings never seated and it's creating a bunch of crank case pressure?
It was dyno'ed before he installed it, so it should be pretty much broken in. I have been in contact with the engine builder some, he is a drag racing guy and has limited knowledge on jet boats. He is actually the one who suggested the vacuum pump, but I haven't ever seen one in a boat.
The guy who built this is very well known in my area, I have no doubt what he is suggesting to me will work, but neither of us have done it before so we both want some opinions on it.
Where is the gasket failing?...Do you have a Pic?....never heard of blown intake gasket, except a blown up engine :hmmm:
this is on my boat
Do you mind telling me a little more about your setup? What kind of pump? How much vacuum? Is it reliable?
The guy I bought it from told me it will push the rubber end seals out from under the intake, no matter how much silicone is on them. But after he installed the breathers and the lines to the exhaust it stopped.
Haven't used traditional manifold end seals on anything in years, first check for fitment (manifold to block and heads) then maybe give thought to punch/peen the ends of the block and mating surfaces on the intake manifold and try a product like right stuff vs supplied end seals. Excess crankcase pressure from worn parts or excessively loose clearances, piston/ring type or design etc can obviously create the issue you describe , assuming the engine has adequate breathers to begin with, think I'd consider running a cylinder leak down and wet/dry compression to determine why amd try to correct the condition (blow by and crankcase pressure ) vs trying to control it on an NA deal
Ain't Right Racin
Check the angle of the head surface and the intake surface. Also make sure the intake bolts don't bind up in the intake bolt holes. This will keep the intake from crushing the gasket enough.
Ain't Right Racin
Haven't used traditional manifold end seals on anything in years, first check for fitment (manifold to block and heads then maybe give thought to punch/peen the ends of the block and mating surfaces on the intake manifold and try a product like right stuff vs end seals , excess crankcase pressure from worn parts or excessively loose clearances, piston/ring type or design etc can obviously create the issue you describe , assuming the engine has adequate breathers to begin with, think I'd consider running a cylinder leak down and wet/dry compression to determine why amd try to correct the condition (blow by and crankcase pressure ) vs trying to control it on an NA deal
You beat me to it
southwindsforsure
I will get info on pump this afternoon
it is adjustable on the vacuum-running 3to 5 right now
this motor came from another boat and had no issues
If the manifold fits the head and block correctly and you use felpro gaskets and good silicone I like permatex ultra gray and not cork or rubber end seals and it actuly blows the shit out (venting the motor to atmosphere) you have big problomes
1 - 12 of 12 Posts
