My solid roller cam is supposed to have lash set at .020 on the intake and .020 on the exhaust when it's hot. Where's it supposed to be set at when cold? (First time being run if it matters.) Thanks!
The engine is growing height wise, so you would subtract from the .020Iron block with aluminum heads. So it sounds like they expand when they get hot (I should have known that). Maybe set them at .023 cold and then after running it for a while check it when it's hot?
my cam calls for 20 also, i set em 22 cold, and i've checked them hot. the 20 was tight but fine. also runnin iron block,alum heads.Iron block with aluminum heads. So it sounds like they expand when they get hot (I should have known that). Maybe set them at .023 cold and then after running it for a while check it when it's hot?
The clearance should "grow" .002-.004 from cold to hot. Set at .018 cold should be about .020-.021 hot.Iron block with aluminum heads. So it sounds like they expand when they get hot (I should have known that). Maybe set them at .023 cold and then after running it for a while check it when it's hot?
So, will you be using the EOIC ( or what ever it is) method or TDC ?So I started thinking I should just finish it myself. So I started this thread. He'll be out here in less than an hour to finish my engine. Thanks for the replies!!!
Makes me wonder if anyone saw this thread...hand
uh uh uhmmm... what?So, will you be using the EOIC ( or what ever it is) method or TDC ?
Sleeper CPbulb
I may be wrong here but when was the last time you saw a REAL race care with a radiator???
Kinda what I just said! Then motor temp got in the way!!!! MThe block is growing but the pushrods are not, set 'em at .022-.024
