Depending on the lobe, the last sets the opening and closing points of the valve.What determines the amount of valve lash in a cam? When a cam maker is making a cam do the numbers that are programed predetermined? Thanks
Yes is a short answer. As Steel has said, it depends on the lobe design. Some cam grinders use a very aggressive "ramp", a steep ramp, that gets the lifter to the point of zero lash, (and the start of the valve "event"), very quickly. The grinder knows when he wants the event to start, and the aggressiveness of the ramp, so he says "lash" the valves at .xxx to keep the designed duration of the "event" accurate... Other grinders use a less aggressive ramp design in an effort to make things easier on the valvetrain components.. And as such, recommend the lash be tighter to once again, keep the advertized duration within their specs.... As you can see, if you run a tighter than spec'd lash you will increase the duration by making the valve event happen a few degrees sooner because the lobe will reach zero lash sooner and start the valve event. Usually a tighter than recommended setting, (.001, .002, .003) will give an engine a little more up top, but you will sacrifice a little down low. By the same token, a looser setting will be a real bear down low, but you'll give up a little up top... Anytime you're messing with the timing of a valve event be sure to recheck piston to valve clearance carefully. Just a few thousandths in a tighter lash can create an exhaust closing later, or an intake opening sooner, piston to valve collision during valve overlap... Sure, we're only talking a minute difference in duration, but sometimes things were already super close. So check it closely if you try "playing" with the settings...What determines the amount of valve lash in a cam? When a cam maker is making a cam do the numbers that are programed predetermined? Thanks
Some lobes are considered "tight lash" lobes, usually with lash <.020".I've always wondered this also.. The last 3 cams that I have ran, duration @ .050" have been around 290 on INT and 305 to 310 on EX with moderate lift, .840/.800.. The lash on them have been .028" to .30" on EX and .030" to .032" on INT.. My new cam is 285/300, .873"/.823" and the lash is quite a bit tighter, .020"/.022" per the cam card.. I thought that was pretty interesting.. Obviously the ramp is a lot faster on the Intake which I would have thought the lash would be around the same as the others.. Should be interesting!!!!
Most lobes are not designed from scratch per a customer's combination. Instead they're chosen from a library of lobes that are "close" and lash can be used to a certain extent, to help "tailor" the lobe more to the customer's specific needs but again. that's all "calculated" and in the end the engine will tell you what it wants. Lash adjustments or "lash loops" should be a part of every engine builder's or racer's testing/tuning program.Yes is a short answer. As Steel has said, it depends on the lobe design. Some cam grinders use a very aggressive "ramp", a steep ramp, that gets the lifter to the point of zero lash, (and the start of the valve "event"), very quickly. The grinder knows when he wants the event to start, and the aggressiveness of the ramp, so he says "lash" the valves at .xxx to keep the designed duration of the "event" accurate... Other grinders use a less aggressive ramp design in an effort to make things easier on the valvetrain components.. And as such, recommend the lash be tighter to once again, keep the advertized duration within their specs.... As you can see, if you run a tighter than spec'd lash you will increase the duration by making the valve event happen a few degrees sooner because the lobe will reach zero lash sooner and start the valve event. Usually a tighter than recommended setting, (.001, .002, .003) will give an engine a little more up top, but you will sacrifice a little down low. By the same token, a looser setting will be a real bear down low, but you'll give up a little up top... Anytime you're messing with the timing of a valve event be sure to recheck piston to valve clearance carefully. Just a few thousandths in a tighter lash can create an exhaust closing later, or an intake opening sooner, piston to valve collision during valve overlap... Sure, we're only talking a minute difference in duration, but sometimes things were already super close. So check it closely if you try "playing" with the settings...
Ray
kinda loose for the cams I've run. lifter type might also affect lash...I've always wondered this also.. The last 3 cams that I have ran, duration @ .050" have been around 290 on INT and 305 to 310 on EX with moderate lift, .840/.800.. The lash on them have been .028" to .30" on EX and .030" to .032" on INT.. My new cam is 285/300, .873"/.823" and the lash is quite a bit tighter, .020"/.022" per the cam card.. I thought that was pretty interesting.. Obviously the ramp is a lot faster on the Intake which I would have thought the lash would be around the same as the others.. Should be interesting!!!!
With the Lunati it had the intake and exhaust lash reversed.. The EX was tighter than the intake which I found unusual at the time.. I called them up and they could only tell that it was a cam design directly from WJ.. I said ok and ran it that way.. But I agree, it was a lot looser than I have ever ran.. But it's still together and in my oldman's Blue boat as a back up motor..kinda loose for the cams I've run. lifter type might also affect lash...
Ray
Well Troy, you might be able to "feel" a difference in the seat of your pants... If a motor seems to fall off, or the boat noses over before you think it should, you can try tightening the lash a couple of thou and see how that feels.. BUT, as I said, messing with the valve "event" timing can create piston to valve clearance issues, so unless you KNOW you have plenty of room to play, DON"T!!!The bottom portion where you loosen and tighten for the lower and upper end is what my engine build explained to me a long time ago. I guess a person would never play with the lash like that unless your at the track to help back it up with numbers unless its that noticeable. Don't know! Might have to play now just to see!
As for the top portion of the page. That is what I was looking for. all you guys have so much good info I just keep making copy's of all of this info. Thanks a lot guys....I'm sure I'll have more questions later. Troy
You'd have to be running p/v clearances really tight in the first place to have a real problem by adjusting lash a few thou. You're looking at about 1* duration for every .002" lash.Well Troy, you might be able to "feel" a difference in the seat of your pants... If a motor seems to fall off, or the boat noses over before you think it should, you can try tightening the lash a couple of thou and see how that feels.. BUT, as I said, messing with the valve "event" timing can create piston to valve clearance issues, so unless you KNOW you have plenty of room to play, DON"T!!!
Ray
Yes Scott I agree, but since I have no idea what, or how, his deal is set up now, I erred on the caution side and suggested he be sure....You'd have to be running p/v clearances really tight in the first place to have a real problem by adjusting lash a few thou. You're looking at about 1* duration for every .002" lash.
Definitely a limitation on loosening lash before damage can/will occur for the exact reason you mention. Usually no more than .004, or .006 for just a pass or two to prove a theory. You can tighten lash as about a far as you want until something hits, or the valve doesn't close.valve lash is something that I have have always tried to learn more about , like when it comes time to setting it on an engine that you don't know what cam is in it . I have always thought it best to be a little tight rather than too loose . maybe the guys that work with cam design can help here but if your lash is more than whats in the clearance ramps doesn't the follower get slammed into the opening ramp and the valve seat get hammered without the slower set down of the closing side clearance ramp ? maybe loosen a little to see whats happens to the power or rpm , but if you need less duration get another cam .
You do have to be a little careful with the ramps get real long and have a large lash, like the 30-30 Duntov flat tappet. There are some old school rollers that fall into this same category. If you lash them too tight in something like a boat, its hard on the exhaust valve. Not only will it open the valve very slowly while on the clearance ramp, and if tightened enough, much sooner than designed. The escaping gases thru the small slow lift, being opened a little early, can torch the valve and possibly the seat. Plus it adds to the exhaust valve heat because its not on the seat as long as it would normally. Just .001 is enough to stop heat transfer to the seat/head.and yet a cam designed with a long clearance ramp can have a lot of lash and still be easy on the valvetrain .
