vertex mag
2897 Views 16 Replies 9 Participants Last post by  obnoxious001
i have a vertex mag for a standard deck chevy with new cap rotor and taylor wires in my motor now and would like to sell it. hows 400 sound? or will trade for an msd set up.
1 - 17 of 17 Posts
Mag
Is it a single wire? Any advance built in, or locked out?.......Smokin' [email protected] $400. ....Ray
by single wire do you mean the one that goes from the mag into the cap. if so yes. and its locked out as it was in a blower motor.
yes it is now that i know what you ment. one ground wire.
it also has a bronze gear for a roller cam
an msd set up would be nice. i need somthing with a rev limiter
you can install a rev limiter box w/ a mag. I have one that worked great, before I crashed and sank the boat, may still work. I beleive msd makes it. I'll go into my parts and check.
Steve
Please call or email for pricing information. 307.856.1637 [email protected]
Magneto High-Range Rev Limiter with RPM Switch
The ETC Inc. High-Range Rev Limiter with RPM Switch was designed to be used exclusively by Nostalgia Racers, giving them engine protection as a high-RPM rev limiter and also an RPM Switch for use with a shift light.
This unit is a unique control device that has been designed to work with all Mallory Magnetos. Models are also available for the Vertex standard internal coil and external coil magnetos. Other types of ignition are available on request.
Adjustable RPM limiting is provided by an adjustable push wheel switch which selects the RPM in increments of 100 from 2,000 to 9,900 RPM causing a switch point when the RPM exceeds the set point.
http://www.etcrevlimiters.com/10.html
I was under the understanding that a mag rev limiter in a blown setup shut the engine down and needed to be reset . if this is wrong i'll keep it and buy the limiter.
If ya can't use it (mag) let me know what's the total shipped to 70582.
Thanks ,Pat
goin to buy the rev limiter and keep this mag. thanks for all the info that's why i love this site. you guys rock.
mag
i would like to buy your mag gary keys 360-731-3012 i also have msd 6al sys.
No offense, but you are looking at an ad that's 4 years old, and he stated he was going to keep the mag and run it.
1 - 17 of 17 Posts
