1 - 2 of 2 Posts
Speed is a function of $$
1994 Cheyenne Jet Boat
19 ft. all original 3 color gel Cheyenne jet. Very clean!! Light layup and currently set up for racing. Setback intake, bubble and speed coat added to bottom of boat. Pump is fresh (built in May). Berkley with Dominator bowl, billet shaft, pre-loader, Hi-helix stainless A, droop, stuffer plate, nozzle machined for inserts (have 4 inserts), reverse bucket, block-off (neutral plate), ride plate, hydraulic place diverter. Hi-Tech Jetaway (ratchet). Currently has air shift (CO2) but have cable and red anodized shifter handle. Hotfoot. Twin 10 gallon stainless saddle tanks that have alcohol ports. Full stringers and full rails. Rails, pump brace, brackets, etc. are all powder coated. Optima redtop battery, battery tray, and cut off switch. Recently re-wired front to back. Auto meter sport comp gauges all work. Bluetooth radio. MSD 6al box. Kill switch. MagnaFuel Pro Star 500 series fuel pump and water separator. All Steel braided lines. Fiberglass bucket seats with matching rear seat included.
Powerhouse
Brand new (built over winter) blown 548 C.I. Big Block Chevy. Only has a few test lake passes for break in. New Dart Big M Block. New Callies crank. Diamond pistons with Molnar rods. Cleveite bearings. AFR aluminum heads complete with comp rockers, guide plates and stud girdles. Nice aluminum Moroso valve covers (welded) with breathers. Littlefield 871 stripped blower with blower restraints. All polished trimmings from Good Vibrations (tensioner pulley, blower pulleys, idler pulley, water port blocks, etc.) 10 quart oil pan with baffles, windage tray, trap doors, etc. Bullet racing cam and lifters. All ARP bolts throughout motor. MSD crank trigger and MSD crab distributor. Basset twisty headers and also have zoomies that come with it. Dual 1050 carbs with all stainless lines and fuel rail.
Double axle road trailer with good boards and good tires. Also have dual axle dolly trailer. Will sell hull less motor if interested. No tire kickers or low ballers please. Garage kept. More pictures upon request.
$$$ 38,000 complete as is
Call or Text - (2 one zero) - 5 Five 1 - Nine 5 1 6
Tyler
1 - 2 of 2 Posts
