1 - 16 of 16 Posts
Frst Round Runnerup
Those kind of things happen when you are running 3 turbos feeding on each other and putting out 100lbs. of boost. Pull the pin on that grenade!
Now thats how you split a block!! :)sphss
Travis
Travis
You could do it this way too; 8,600 through the lights with a stock crank:
Since everything went out the bottom the Very good heads were fine. My friend found two pitons in the wrong holes.
Sleeper CP :D
Sleeper CP :D
Why spend the money on very good heads and aluminum rods but not upgrade the crank.....??
Travis
Oh yea, that's a dandy, and the ride trying to drive over the block (pieces).
'Course, that little Ford (if I recall Sleeper's picture correctly from the first time I saw it) had to be one heck of a sound too. ;)
Upgrading the crank seems to be a no-brainer in that case.
Apparently a "no-brainer" did not think so. ;)
Travis
Friend who purchased the car the guy who sold it to him said it had a few part's that didn't appear under closer inspection.
He was over doing it a tad at 8,600.
S CP :D
Distinguished Member
Yea, we run aluminum rods. See??
I hate it when I do that :)
Run over my own spit out scrap metal fit.
I like the thick steel scatter shield plate on the side of the engine, and the hit it took. Imagine where those pieces would have ended up!
I was talking to a guy last weekend that runs a all aluminum blown alochol small block in a sand car his quote was "Its amazing how much shit breaks in 60 feet" Classic line I thought.
1 - 16 of 16 Posts
