1 - 20 of 32 Posts
senior member
any ideas how to make this set-up look decent? the adapters they made look hidious:mad:.i want to keep the logs if possible. any better adapter ideas or????thanks ,turbo wog Motor vehicle Vehicle Engine Auto part Car
Engine Motor vehicle Auto part Vehicle Automotive engine part
Auto part Pump Engine Machine Pipe
I dont think those look to bad, you will have to keep them in that spot if you want to keep the log's though. I would have made them so they came out the side of the adapter pointing to the outside of the hull. Then point the dump straight up and make a nice pipe with a 90 degree bend in it to dump out the back of the boat with the exhaust off the turbines.
You could still do this if you cut the existing pipe off flush and get a couple a tight radius 90's!! That will point them to the outsides of the hull then you can build some good looking dump tubes!
Travis
senior member
Discussion Starter · #3 ·
thanks! they were supposed to come out the side they told me they were gonna be @1 1/2" tall
Lookin good Paul!
any ideas how to make this set-up look decent? the adapters they made look hidious:mad:.i want to keep the logs if possible. any better adapter ideas or????thanks ,turbo wog View attachment 49674
Those WG's are pretty close to the fiberglass, not sure how hot they will get . . . can you rotate them? Another option could be to add turbo header flange as a spacer but that might change other geometry . . . . fockin turbos!:|err
:D Hey sorry I missed your call the other night . . . out workin on the hydro:)devil
senior member
Discussion Starter · #5 ·
hey scott,the adapters are being sent back:|err. they were supposed to come out the side. gotta have new ones made:mad:turbos being sent back too:mad: . i'm out for a few more weeks:mad:. uness i get some temparary turbos or exaust & run no turbos for now:)bulb.
Can you unbolt the elbow and bolt on a over the trans pipe? If so I have a pair that have your name on them (for a Mondelo or three:D) they are slightly used chrome with a flat flange you can drill if you need to . . . . anything to get Turbowog Racing back out there . . . :)devil
Let me know bro
senior member
Discussion Starter · #7 ·
Let me know bro
got any pics? i can pull off the whole exaust for now!
Even though they are redoing them for you, you could make them look a little cleaner. Although, I don't think they look bad.
For a cleaner look, have them weld the nuts in place, then cap the whole thing with sheet metal. This way it will look more similar in size to the logs that they are coming off of.
senior member
Discussion Starter · #11 · (Edited)
thank you s2k1. thats what i thought. not very clean at all right now. i want them built out of a solid peice of aluminum, but the seat for the waiste gate is stainless. i wonder if they can braze alum. to stainless?
Jet Hot (or similar) coat the riser/wastegate housings and they will hardly be noticable when it is all done.
wastegate adapters
I dont know how much you can tell from this old pic, but here are the ones that an old friend of mine wittled out of stainless, he has since passed away, sure do miss 'em he was a great guy and a hell of a machinist.
senior member
Discussion Starter · #14 ·
thanks has:D:D do you know if that is a solid piece of ss or like a tube with a inner tube?
senior member
Discussion Starter · #15 ·
i think this will look way better.. what do you guys think? this is the very first draft! Text Font Wood Paper Drawing
not sure if i'm going off the side or the rear in a upward angle or straight ..
Its a solid piece of stainless and the large hole that goes through it starts off the size of the outlet in the aluminum elbow and funnels out to the size of the inlet on the t04 turbo, they dont match up very well so my bud made them match the adapter.
TurboWog, I"ve got a set of aluminum risers that are designed for wastegates to bolt directly to them if your interested shoot me a pm.
Hass,
If TurboWog is not interested in the risers, I might be. Do you have any pics?
Thank You,
Earle
private message him, he checks it in the evening;)
Paulie'.......
Bring it by....lets hav a looksie!
senior member
Discussion Starter · #20 ·
hey matt, i am actually going to have them machined out of billet with some cool fins on them . kinda like my valve covers but not exactly. it will look propper:D gotta get those 50mm waist gates on lookin right .call me about labor day .. what's up?
1 - 20 of 32 Posts
