1 - 4 of 4 Posts
Looking for good working set of Corsa Captains call diverters. To fit 5.0-6.2 mercruiser. I believe the Corsa part number is 13091. Thanks
New here
Can we assume you already have thru-hull exhaust and want an occasional quieter option? Or are you currently still thru-prop and want to add thru-hull?
IF you already have thru-hull and want to flip a switch for quieter - there's easier and less expensive options:Standard Angle Cut Air Operated Switchable Transom Mount Silencer Kit - CP Performance
IF you want to keep thru-prop, you will have the cost of the Corsa system PLUS all of the extra plumbing to connect both (outdrive Y and hull tips).
I have thru hull, Corsa quick and quiet II. So it goes thru the hull and prop, but no switch to have it go through the prop or just the hull. Just want the option to make it quiet when needed
New here
So the valves and plumbing are ALREADY in place? All you need is the SWITCH itself??
1 - 4 of 4 Posts
