1 - 12 of 12 Posts
"The" masheenist
Anything can be made
BTC cardcarrying member
Discussion Starter · #4 ·
What I'm trying to do is :)bulb
I run a 6/7deg wedge and everytime I change a wedge I bend the studs.
And to me that is a lot of stress on the stud right at the nut.
Anyone have an 4deg Alum wedge???????
I think if I cut a 4deg in half and grind it to fit on the out side of the droop flange my problem will be solved:D
What about fliping the wedge not cutting and grinding? WT:)devil
Anyone know were I can get some 4deg 5/16 washers:)bulb
yes, but they are kinda spendy @ 20 washers for $50.00 USD. The pluse side is any diameter up to 1" and any wedge you want between 2 to 10 degrees. This offer is only good until I switch over to the hex stock that's next in line. Aka you have a few days.
"The" masheenist
yes,I can custom make you 20 washers for $50.00 USD. Any diameter up to 1" and any wedge you want between 2 to 10 degrees. This offer is only good until I switch over to the hex stock that's next in line. Aka you have a few days.
There you go Dave.
Discussion Starter · #9 ·
Dave thanks If I can't find an Alum wedge I will give you a call.
1 - 12 of 12 Posts
