What are the symptoms of water in your gas (motor running wise)? I think im having that problem with my boat. I do not have fuel vents on my tanks. Is this also worse for preventing condensation buildup in the tanks?
Sputtering ,missing at steady speed , bogs hesitations etc , the moisture will also cause white oxidation to form in the carb body too! Vents are easy to install either by adding them or putting in vented caps , Most modern fills are vented or have the ability to be either /or. Brendellas right about the water trap to help control the moisture that likley already exists as well Call if we can help
Tom
BTW I'm told that denatured alchohol (hardware stores) helps absorb and "process" some of the moisture thru the system , however we drain ,seperate (let stand in a clear jug) and then "mop out" (thru the filler) all remaining moisture with lint free absorbant cloth till all traces are gone
