I am doing the same thing. You also might want to plug the pee holes with sheet metal screws to eliminate false air. Here is a pic of what I did.
T.J.
T.J.
THAT HOSE WON'T LAST MORE THEN ABOUT 5 MINS UNDER WAY BEFORE IT GETS HOT AND MELTS THROUGH KEEP A CLOSE EYE ON IT WHILE RUNNING IT WITH KNOW WATER, AND BE SURE YOU DON'T GET THE MANIFOILD TO HOT, AS YOU COULD WARP IT! GOOD LUCK!If I was going ot's I wouldn't worry about it, I'm going tt's. I'll try it and keep ya all posted, I think it will be fine.
THAT HOSE WON'T LAST MORE THEN ABOUT 5 MINS UNDER WAY BEFORE IT GETS HOT AND MELTS THROUGH KEEP A CLOSE EYE ON IT WHILE RUNNING IT WITH KNOW WATER, AND BE SURE YOU DON'T GET THE MANIFOILD TO HOT, AS YOU COULD WARP IT! GOOD LUCK!devil
