Most meth/water injection tanks are on the small side, feeeding 4 nozzles on 2 motors will most likely go thru the stuff pretty fast. Id like to just spray water and I had this crazy idea of plumbing it to my bellhousing to have a unlimited supply. Anyone ever try this?
I`d use a filter to keep the junk out like : The Best Water injection system and water methanol injection systems at AlcoholInjectionSystems.com
Lake Michigan is generally pretty clean water and first line of defense is my strainer, them filter than screen at injector.
My only concern is having 20 psi on the suction side.. if it pushes thru the pump then my whole idea is a bust.
