1 - 10 of 10 Posts
I'm runnin a magnaflow water pump on the hydro, 392 chrysler hemi, pick up tube is the rudder, it keeps blowin one freeze plug out, should I have a valve on the inlet or what??????????
We ran that same setup on our Hydro..Check the impeller before you do anything else to it.. Force feeding the pump seemed to abuse the impeller abit..If it's broken a vain or two off it may cause it to pulse the pressure in the block...And be sure the freeze plugs are good ones & installed/fit properly.. Also check the water dump as it may have a restriction somewhere..
Purple headed member
the hemis have those stupid disc typle freeze plugs and the block has been filled to the bottom of the freeze plugs, but I am going to check for a restriction
Take the impeller out and cut off every other blade then re-install it Should solve the problem. And at 120mph the impeller is a restriction more than anything else.
hyroman,
i run the same set-up,1 with a 392 & 1 with a 454 in a hydro with the pick-up off the rudder & it works fine. we use 5/8 o.d. stianless tube with #10 hose going to a mike kuhl pmp.with alcohol it works too good because i can't get enough heat in the motor. hopefully this helps. good luck.
1 - 10 of 10 Posts
