1 - 14 of 14 Posts
use a BBC to pull a BBC
anyone have a picture or diagram for one with logs?? mine has the nicson logs and I just blew my intake gasket (first time out) :mad: but want to make sure that its routed right, I am not running a stat, do you guys think I need to regulate flow to the engine with a ball valve or something?? any help is appreciated!! :)devil
Member
There was a real good thread awhile back regarding plumbing.....except with headers. I've got the logs and I was told to put a ball valve (gas valve w/smaller handle) at the jet, this keeps you from pumping water into your boat if you spring a leak in a heater hose. Then 'T' it and go into both fittings where the water pump would be, then out the t-stat housing and into the logs.
mine comes in from the pump then T'S and goes to the front of the logs and then from there another fitting on the front of the logs to the water pump cover and from the stat housing goes back to the bottom of the riser. let me know if this is right.
That is right.
When I ran logs, that was the way they belonged.
Cool the logs first (and pre-heat the engine water), then to the engine, then out to the outlest.
Member
Crap!! you're right. I looked back at HJ's thread regarding plumbing and found what I was looking for. I remembered incorrectly. Sorry Devonwon, didn't mean to give you bad info. Here's the link with the diagram someone posted (post #160).
http://www.performanceboats.com//showthread.php?t=6571&page=6
This THE WAY to plumb a jet with logs. Pre-heat the water then send to the motor. Motor runs warmer and the motor runs at a temp that is more motor friendly. That is how I plumbed mine and very happy with the set-up. Never seen over 195 or under 160 at cruise or WOT. M
Member
The timing on this thread is pretty good, I'm about to finalize some stuff before I start my motor this week so I can change my mistake easily. Just curious though.....does it really matter which direction you run the water through the motor? I think my hoses would look better running into the t-stat and out of the water pump plate.
Sit N' Spin
What works really well on my setup is the relief valve with the thermostat kit.
It uses the Hardin Marine thermostat kit and a pressure relief valve set to open at 12 PSI. You can get the valve at McMaster Carr for about $50. Their part number for it is 9763K12 and their website is http://www.mcmaster.com
On my setup I run the water full on unrestricted from the pump. The relief valve keeps it from overpressurizing the motor and running the water full on gives you full water volume to completely fill the block, ensuring a constant running temp rather than idling at 180 and shock cooling it when you get on the throttle. The thermostat allows the engine to get up to about 140* with a 160* thermostat.
After about 35 hours I have no water in the oil and a constant running temp of 140*. No shock cooling whatsoever.
Now I run OT Bassetts but I'm thinking it should work just as well with logs. Here's the diagram shown with logs. The ball valve off the pump is fully on all the time and is there as an emergency shutoff.
Yes it does.
It would be like trying to fill a beer can up with a hole in the bottom. It wouldn't stay full of water all the time and would have could have hot spots. There was a thread earlier about changing the direction of flow and the general opinion was Engine builders put a lot of research into water flow and disinged engine flow to go in at the waterpump and out the t housing also if you changed direction (water in at the T housing) if you run a thermostat it wouldn't regulate your engine temp cause it would be reacting to the incoming water temp.
Member
Yes it does.
That makes perfect sense. Thanks.
... I just blew my intake gasket (first time out)...
I know you have a 455 Olds, if you are running a aftermarket aluminum intake manifold you need to run a special intake manifold gasket set for that application (Felpro make sit). The stock intakes use a valley pan which you are not going to want to run with an aftermarket intake. So far I've seen 4 blown Olds 455's in boats that I parted out because of incorrect intake manifold installation (using silicone only or silicone and gasket on the intake manifold). Use the correct gasket (assuming you have a aftermarket intake) and you won't have any problems.
... do you guys think I need to regulate flow to the engine with a ball valve or something??...
You need to have a valve (ball or gate will work) between the pump and the engine. Start off with the valve about 1/3 open and adjust the valve to get the engine temp where you want it.
1 - 14 of 14 Posts
