1 - 7 of 7 Posts
anyone out there know how many turns in or out yours is set at and the pressure reading, the valve is 1/2 inch.
I just installed one but i haven't installed psi gauge yet
jetboataholic
i keep mine were as soon as the motor is started, it puking out a small stream outta the back, then as soon as i throttle up, its bypassing pressure pretty good by then. setting the thing with air pressure or a water hose is pointless, trust me;)
A pressure gauge is the only correct way to set the valves for correct block pressure in your application.
jetboataholic
Go to tractor supply and pick yourself up a $30 pressure gauge!:D
1 - 7 of 7 Posts
