1 - 7 of 7 Posts
What's the best bang for the buck on a hand held weather station ?
Don't want to spend a small fortune.
Sleeper CP
Big Inch Ford Lover :D
i've been using a performaireII for the last 7 years. had to send it back in a couple times (it got wet once), but tech support is excellent.
i have been using the orange kestral unit out of jegs...i think its like $239.99...works great for what i need...if you shop around on the internet you can get a better price...i think i got mine for $219.99
Density gauge
If you're on a limited budget, and what racer type isn't, call Kinsler Injection and get one of their calibrated Air Density Gauges. About a buck 40, ($140.). Once you establish a base line tune up the adjustments almost make themselves. Percentage of density change is in direct relation to the percentage of fuel/air ratio changes..........Works very well for us..........Ray
PS The percentage of change is determined using the AREA of the orifice, not the diameter......
Discussion Starter · #7 ·
Thanks guy's. I'll check on what you told me.
Thanks,
Sleeper CP :D
1 - 7 of 7 Posts
