1 - 1 of 1 Posts
In the hunt!
I bought this for my new pontoon but fortunately before I installed $1500 worth of stereo equipment, the manufacturer purchased the boat back.
I am selling this to recoup my costs on this amp - It is new in the box and never installed.
Wet Sounds™ Hydro‐Tech™ Series Marine Amplifiers are designed to be a complete solution for every type of extreme marine application. The HT-4 is a high powered marine 4 ch full range class d amplifier that allows you to configure it to power any combination of speakers systems.
The HT-4 can run multiple Marine Speakers, Marine Speakers and subwoofers, Marine Speakers and tower speakers, tower speakers and subwoofers, multiple subwoofers or used to power tower speakers. High Pass, Low pass and Full range crossover selection on all channels with bass boost adjustment increase the flexibility. Adding to the feature set is RCA input summing that allows you to attach one set of RCA's to drive all channels or separate the amp into 2 RCA inputs. This makes it very simple to wire and configure the amplifier without the need for additional RCA Y-adapters. Removable power/ground and speaker wire plugs giving you easier installation for wiring up the amplifier in tight space.
SPECIFICATIONS
  • full-range 4-channel marine amplifier
  • Class-D design
  • 110 watts RMS x 4 at 4 ohms (150 watts RMS x 4 at 2 ohms)
  • 300 watts RMS x 2 at 4 ohms in bridged mode
  • frequency response: 10-20,000 Hz
  • variable low-pass and high-pass crossovers on channels 1/2 and 3/4
  • variable bass boost: 0-12 dB at 45 Hz
  • rugged water-resistant design
  • dimensions: 11"W x 7-5/16"D x 2-5/16"H
$300 plus actual shipping costs. Shipping in CONUS only!
1 - 1 of 1 Posts
