1 - 19 of 19 Posts
Before I get the engine in the works I want to make sure I have all my cookies in a jar. Help me compile a list of what I need so I can start ordering parts. a 650HP BBC Swap. 1971 Chevelle, built TH400 Trans, 12 Bolt with Posi and 3.55 gears, Lakewood lift bars, rear stabalizer so far I know I need this following, but having a brain fart
*Already have solid Motor Mounts
Torque Converter
4 Core Radiator
Twin Electric Fans
Pulleys/Brackets
Headers
U-Joint upgrade
New shocks and coil springs (need anyways)
what happened with the stroker sbc ?
NO REPLACEMENT FOR DISPLACEMENT :D
We have the 502, but I want to R & D a new build to sell so were going to build a 505 or 510ci, 4340 forged bottom end, Profiler Heads, either a Sniper Intake or Edel Victor R manifold.
Once its in im going to lay down some 1/8 and 1/4 mile numbers for the Team Chevelle website as well. :)devil
yes there is, we folks from okla. call it BOOST:D the bs'n we did awhile back when you 1st got the car put ideas in my head bout a big hp sbc, and my bigggg turbo for my sbc came in today:)devil:D
I'm famous !
fuel pump , bigger lines, tranny cooler , I would upgrade the axles in that rearend , you will have to do some work to get it to hook up - those chevelles are chanllenging at times to bite . I would also stiffen up the chassis a lil so you don't pancake the car . To help us out - what are you going to use the car for ?
Torque Converter
4 Core Radiator
Twin Electric Fans
Pulleys/Brackets
Headers
U-Joint upgrade
I'm famous !
Don't forget your solid tranny mount - Or you will be very unhappy :D
Torque Converter
4 Core Radiator
Twin Electric Fans
Pulleys/Brackets
Headers
U-Joint upgrade
Nice...that should be damn bitchen!!!! :D I want the sbc but this will kill a few birds with one stone...and I dont mind.
It is going to be a Street Strip car. About 70% Street 30% strip. I havent checked to see if it was a C clip rear end or not...I was just gonna run it till she went and have Currie build me up a nice 9 inch. I will also be running some M/T Street Radials :)devil
Torque Converter
4 Core Radiator
Twin Electric Fans
Pulleys/Brackets
Headers
U-Joint upgrade
Springs? What brand? I used Moroso Trick front and rear had good luck with them! It's a blast to drive out of the hole on one RR Tire! LOL! Rollcage will help the twist problem! 79 malibu 3300# car 1.24 60ft. times 6.30 118-122 MPH 1/8 mile all stock car! 468BBC 725-750hp, springs F/R and 8.5 456 10bolt rear no C clips and prayed it would holdup! Have Fun! WT:)devil
Cantard
The edelbrock bars seem to work alot better than the lakewood stuff.
Cheap 50/50 shocks and a anti roll bar and your gona have no problems. Anti roll bar bit of a pain to put in one of those but work absolutly awesome. No more air bags which are just a bandaid anyways.
Got a converter you would probably really like.
Buy the motor mounts made by all star... much stonger than the pos moroso bent and splitting in half ones.
Distinguished Member
......It is going to be a Street Strip car. About 70% Street 30% strip. I havent checked to see if it was a C clip rear end or not...I was just gonna run it till she went and have Currie build me up a nice 9 inch. :)devil
Bad idea man. When a c'clip rear end fails, the axle pulls out and bad things happen with the rear wheel. A Curry or Chassis works RE is the best idea, but if your out of $$$ at least upgrade the axles in the 12 bolt.
Good luck
Sure there is, Nascar runs small blocks that are pushing 800 hp. Obviously you can get much more from a 502 but how much do you really need. You should be able to get what you want out of a small block.
What Nascar motors lack in displacement they more than make up for in $$$. Cup motors are insanely expensive.
We ran small blocks when we raced NHRA and it's pretty easy to build a 650+ HP SBC. However, the same $$ will easily get you 850+ in a BBC. In a heavy street car like a Chevelle, a BBC is the only way to go. Been there, done that.
Cantard
I am doing a "just fix it up" on a disaster right now I can take a pic of the suspension I am trying to make something of. Something like your package is usualy good for a 1.45 ish 60ft with no transbrake on a 28x9 tire. Its a 66 but pretty much same parts.
I'm famous !
ya and out of a bigblock you can pull 1600 whats your point
Discussion Starter #17
I was actually looking at the Edelbrock package...especially since I can get a superb deal. Looks like an axle upgrade temporaily will be key.
Discussion Starter #18
Yeah but thats when Streetability goes out the window and the price tag goes up :D
Discussion Starter #19
So heres my list so far....may change somethings...not sure, but the jist of it...tranny and u joints started fockin up a couple days ago...so im speeding up the task! :)sphss
  • Headers- Hooker Comps Ceramic Coated #2455-1HKR
  • U-Joints/1350-
  • Radiator- Northern #205026 or summit #380457
  • Electric Fans-Northern #Z40004
  • Pulleys/Brackets-not sure yet
  • MSD 6AL2 Box #6421
  • Moroso Trick Rear Springs #47500
  • Moroso Trick Front Springs #47135
  • Competition Engineering Front ADJ Shock #C2600
  • Competition Engineering Rear ADJ Shock #C2720
  • Moser Axles-
  • Moser C Clip Eliminators-
1 - 19 of 19 Posts
