Long story short.. I have brand x starter and it sits too low to the flywheel. It's tight enough when you stick the pinon gear on the starter with a screw driver it wont retract(I guess the motor kicks it out). Last year it was about 50/50 cross your fingers hit the key and hope you don't grind. This year, new motor,she ain't going in period(the pinion gear to starter ring gear). I called Jan @ lightning and asked him if I could trade him my old starter stand for a .030 thousands one, and he sent me a new .030 taller one for free. I bolt it on and it grinds. I cut some new shims to bring the starter closer to the flywheel and whala(sp?) she works great, until last weekend. Where it's sitting right now I can't pull the starter gear in I can see the flex plate bend from me trying. I don't know if.... the only clue I have is that where it's froze up now the left side of the flexplate looks chewed a little, and the right side ,not so much. I'm thinking flexplate??? What starter are you guys running with lightning rail kits?
Sorry that ended up as long as it did..
