1 - 4 of 4 Posts
Bahner tunnel guy
I need to replace a prop and would like to get the same size and pitch of this one.
48-77320-24 is the part number. Thanks in advance.
Bahner tunnel guy
Thanks Jordy, it's off of my Bahner tunnel hull. It has a Black max 200 on it, and is 19' long. I may want to get something that may help it pull a skier out of the water faster, so I may have to give Kevin a call to see if what he thinks I should go with. This Prop is basically made for High speed. I could use something with a little less speed and more torque.
Kevin is an outboard guy and should be able to hook you up with what you're looking for... he's got the prop voodoo down!!! :D
1 - 4 of 4 Posts
