1 - 4 of 4 Posts
I bought a 22.5' kachina la bala has a bravo 1 with a 454 mpi motor and have no idea what prop to use it has no prop on it when I bought it, was stolen. any help is appreciated. looking for a good all around prop more on the mid to top end dont ski or tube at all
PASO ROBLES CA
If the motor is in good shape and based on the fact your not gonna pull a skier,I would try a 24 pitch Bravo 4. Your 454 should pull it.You can find used ones for about $350 bucks . Good Luck
thanks will try that also what is the difference between bravo 1 props and brovo 3 ect
I have a prop that you can try out..I live just up the road from you. 951-926- six one six one, bigmike
fyi..a bravo3 drive uses two props, counter rotating
1 - 4 of 4 Posts
