I myself prefer one that works. They seem to be the most common.What are you guy's having good luck with?? I'm pretty frustrated right now and I don't want to say anything I'll regret. I'll stick up a pic in a minute. Of todays carnage. My boat almost started.sphss
I didn't know you could get a top mount/reverse rotation starter from pep boysi use the the heavy cast iron chevy 4 speed one you can get any where at pep boys auto zone with 13to 1 and a locked out distributor its been in for over 10 years and no broken nose and if it takes a dump its ez to replace and my boat stays on the water not the trailer
I don't belive you can ? I suspect Chuck was meaning a "bottom mount" in response to your question . Kreg what "precipitated this latest deal? JK did you get the pinion depth engagement/plate adaptor deal ironed out ? is there a chance this was a "too much initial timing issue (starter "kick back") ? TomI didn't know you could get a top mount/reverse rotation starter from pep boysgrn
It spins over my 15 to 1 motor like it has no spark plugs in it.
I had one of those in my 21' cruiser, that was one great starter. no problem with 10.5 to 1 locked out dizzy. always started.I run the large 14MT DELCO STARTER MERCRUISER MARINE as well since 91'. Never an issue.489ci, locked out dist, supercharged.
Even had an old motor Hydraulic once (stuck fuel solenoid, NOS) still turned the dam thing over.
Run a flexplate no Flyheel...FYI
RE
Mike Miller got in touch with IMI and figured this one out.
tom i did think bottom mount sorry should have looked at what in was readingI don't belive you can ? I suspect Chuck was meaning a "bottom mount" in response to your question . Kreg what "precipitated this latest deal? JK did you get the pinion depth engagement/plate adaptor deal ironed out ? is there a chance this was a "too much initial timing issue (starter "kick back") ? Tom
Just lookin out for ya Bud , got a new Tilton style "mini" bottom mount on my new motor, special built with extra small pinion works Killer !tom i did think bottom mount sorry should have looked at what in was reading
I'm locked out Tom, it may have kicked back. It started once and then died, unfortunatley that's pretty normal for my junk when it's ice cold and hasn't ran for a month or more. I went to start it again and bnag! I'm not sure if it didn't "kick back" to be honest. As far as the flexplate it's a brand new sfi cert unit. I struggled with the starter being too close for a year. The last time I posted an "I hate my starter thread" outlaw recomended some offset dowls. I did that and changed the stock flexplate out at the same time. Well aparently the stock flexplate is a wee bit larger in dia. than the aftermarket one.:|err So now if anything I'm too loose. To add insult to injury in july it quit working so I had a local shop "rebuild" it. Aparently they didn't do chit acording to the manuf. It appears that it snatched the threads where that small 1/16 ish looking bolt goes into the housing. I dunno.... I'm sure your all sick of me whining about my starter. I probably should have kept this thread/problem to myself. I guess I just wanted to vent a lil. I'm over it...sorry guys.I don't belive you can ? I suspect Chuck was meaning a "bottom mount" in response to your question . Kreg what "precipitated this latest deal? JK did you get the pinion depth engagement/plate adaptor deal ironed out ? is there a chance this was a "too much initial timing issue (starter "kick back") ? Tom
...shouldn't being the operative word. if that hole is as hogged out as it looks, it'll eventually move due to the repeated torque against it, even if alignment checks perfectly when it's first installed. seen so many flails with top mounts, it's sick, and it seems like it's always at the wrong time.The holes in the IMI starters do not locate the starter. Oblong holes shouldn't matter, as long as it fits tight into the starter adapter. But I would always check engagement with dykem
