You still need to turn your shaft and mill the shaft for a keyway like any inducer install, the inducer fits as is, no machining on the part itself.does it work as is or does it need to be turned down?
S CP
That is the Precision Jet Drive billet inducer. Made in Ca.
I'm pretty sure the blades overlap too much.i think i read some where or heard the pitch on blades was not good?
hell if i know :duh:
Are DPS inducers any good?You still need to turn your shaft and mill the shaft for a keyway like any inducer install, the inducer fits as is, no machining on the part itself.
We dont run those inducers in any of our stuff.
That's what I was going to do with mine this go around, but I worried about balancing issues. It made such a big improvement over what I had before, which was nothing, I just decided to leave it. Not really looking for tenths at this point.If your not running one now , it should certainly be an improvement. Would be even better if you cut the blades back so they didnt overlap. And lastly if you wanted to go even further you could thin the barrel down a bit. This is all JMO.
Thanks!If your not running one now , it should certainly be an improvement. Would be even better if you cut the blades back so they didnt overlap. And lastly if you wanted to go even further you could thin the barrel down a bit. This is all JMO.
There are others out there that will work better.i was pretty sure that was what it was called.
my shaft is already set-up for a inducer.
i guess im wanting to know if they are worth a shit,lol!?
i need one and if this one will compare to a HTM or a detailed DPS then ill try it.if not ill give it back to Dad and tell him sell it to somebody he doesn't like,lol!
i gave this one back to Dad and he is going to have it worked over by a anonymous source.FWIW Trav I'm runnin the HM in both my boats. Got the 1 for the Cheyenne @ B1. Well worth the $$$$$. JMO![]()
i bought 1 from Chris @ B1 today.
Thanks Everyone for the low down and Advice.
Travis
