1 - 16 of 16 Posts
Speedy Member
eTrex® H
Part Number: 010-00631-00
Suggested Retail Price: $ 99.99 USD
If you gonna get a handheld, this is the Garmin you want. Its easy and durable. (Kinda like quickjet)
Speedy Member
What do you use? :)bulb
IQ3 Logger Dash
 Filter Product
Pressure
Temperature
RPM
Travel
Air/Fuel
Cables
Weather Station
Mounting Brackets
Driveshaft Collars
250-DS-IQ3LD· 32 Channels
· Internally Mounted GPS
· Internal 3 Axis G Meter
· 512MB microSD Memory Card
· Programmable Shift Lights
· Programmable Warning Lights With On Screen Warning
· 24 Programmable Sensor Inputs On 4 Pages
· Programmable 5 Character Channel Name
· Gear Indicator
· Predictive Lap Time
· Prop Slip and Prop Speed for Boats
· Power/Ground/Engine RPM/
External Programming Buttons Harness
· Speed, Lap Time, Lap No. From GPS
· Downloaded Data Provides Track Mapping, Segment Times, Data Reports
· Includes DatalinkII Data Analysis · Software and Installation Manual
· Metric / Imperial Configurable Sample Rates:
Up to 100 samples per second
Memory :
SD memory card
Recording time depends on number of channels monitored and sample rates
The IQ3 dash represents an entirely new concept in data logging dashes. By placing the 32 channel data logger, 512 MB memory card, GPS board and 3 axis G meter inside the dash, every feature of the data system is now located in one central location.
And, when that 32 channel data logger is one of Racepak’s exclusive smart sensor type, that means that only one small cable will transmit the data from all the sensors to the rear of the dash.
So, for the customer, this means:
  • No external data logger necessary
  • No bulky, heavy sensor wiring harness
  • No beacon transmitter or receiver necessary for lap time data
  • No wheel speed sensor necessary. GPS provides speed and track mapping
The IQ3 data logger dash is designed to be a complete data center. Contained inside the fully programmable dash is a 32 channel data logger, 512 MB microSD memory card, GPS board and 3 axis G meter. The programmable shift lights are protected from sunlight by a molded shield above the lights, while the low glare LCD display is well recessed in the housing in order to provide viewing in all light conditions.
The rear of the dash contains the connectors for the external GPS antenna, Vnet sensor cable and the Power / Ground / Engine RPM / External Programming Button harness. All sensors transmit their data through a single cable (Vnet) which is routed to the rear of the dash. This eliminates the need for a sensor harness, greatly reducing installation time, complexity and overall weight.
All data is stored in a 512 MB MicroSD memory card, located in the front of the dash between the programmable shift lights. This design insures easy access to the memory card for data download.
Our boat customers will appreciate the ability to display prop slip and prop speed, providing valuable information when performing prop testing.
Click here to add this page to your favorites
30402 Esperanza, Rancho Santa Margarita, California 92688 • Phone: 949-709-5555 • Fax (949) 709-5556
All text, descriptions, software, images, and other content of this website are the property of Competition Systems, Incorporated. All rights reserved.
She is totally hot until she starts talking.
that's funny...
with a chick that hot...i wouldn't be thinking about talking..
do you have her number ?
how is she with kids ,
i'm thinking about starting a family...LOL !
oh yeah.. what will she do on the gps ?
The garmin works real nice. Keep it mounted so it has a good window to the sky. Garmin makes a handle bar mount that I have used with good success. Or just some velcro to the battery cover.
You need to hold you top speed & let it catch up. But they seem to be real accurate.
Nice pictures BTW............
1 - 16 of 16 Posts
