I went to a plumbing supply house and pick up 4" drain pipe plugs. Mine have a metal piece with a wingnut to tighten up so the rubber swells and plugs the exhaust end.Where to buy...........Header collector rubber cap covers?? Looking for a source to buy soft shinny rubber covers that slip over outside a 4" straight collector!!
ANY IDEAS.........a lot of you guys have them!!
Thanks, John
good idea...I went to a plumbing supply house and pick up 4" drain pipe plugs. Mine have a metal piece with a wingnut to tighten up so the rubber swells and plugs the exhaust end.
I still don't know how to post a pic otherwise i would....sorry
Bubba
Grainger shows a pic with the Metal plate !!!
I had some small Nerf balls that I ran in my old upswept Borlas. My wife looped through some string and made it easy to pull them out. They werent footballs but worked really wellI saw a pair of Nerf footballs stuffed into the collectors. They even matched the boat colors.
What'd you end up with?Problem Solved.................Thanks for all your input!!!!!!!!!!!!
Cheers............
