This just seems too general to me. 4.5" stroke 7500rpm vs. 4" at 6500 could mean the difference between ticking time bomb and hundreds of hours on the water, couldn't it? Is it really a ticking time bomb? May it just as easily fail at 10 hours as it may at 15, 20, 100, 150? Should the owner of an engine with aluminum rods have no expected reliable service time frame?
There isn't enough data to determine how long an aluminum rod will survive in a non race situation. Too many variables. Piston and pin weight play a huge part of besides stroke and RPM. Companies like Miller have a good idea how long they will survive in a fueler or blown alky deal, but then so do the racers.
I imagine the pro stock guys do as well. How long it last in a street car, or recreational boat is hard to nail down. How many times did it get buzzed to 7000, and for how long? An hour meter or rev counter is useless. No telling how long the rods were near yield.
Then you have to take into account the rod itself. GRP, or MGP machined from 7075 mill plate, or a Miller, or Alan Johnson/C&A forging? There is a HUGE difference.
Unlike steel, unless you keep the rod well below its yield point, every cycle is held in memory, and the yield is way lower than steel. Forces at 6000 that may never fail a steel rod, will in time fail a aluminum rod. Question is, when? I guess that depends on how many times you ran it 8000. Where the steel rod may only "remember' the 8000 blast, the aluminum rod remembers all the time at 6000 as well.
Because its impossible to make aluminum with the same tensile strength of 4340 or 300M, forces that are well below the yield of the steel rods have no real effect on it life span. But those forces can very well be very close to the aluminum's yield, and it does shorten the rods life.
The big thing too many over look as well is, that temperature will shorten an aluminum rods life as fast as stress loads. The life span difference of a aluminum rod with 300 degree oil is huge compared to 250. The tensile strength of aluminum plummets at temperatures steel laughs at. I wouldn't even consider a performance boat with aluminum rods and no oil cooler.
Rods forged from 2024 take the heat a little better, but all those rod manufactures are gone.
If aluminum rod at 6000 rpm will eventually fail, and it will, the cost of having to replace them just exceeded a set of Carrillos with Carr bolts if you had bought them in the first place. And the Carrillo and the bolt will out live you at that RPM
