When I had my Whippled 502 the intercooler water was not supplied by the water pump, it in fact grabbed water before the pump and before the sea strainer. I am not sure if it really matters but I was told that the water for the intercooler should not be feed by the pump. As far as temps go, my motor as it was set up ran a shade over 100 degrees which is fine. What you want to make sure is that your oil is getting warm. Anything between 220 and 240 on your oil and you’re dialed. As long as the oil is hot enough to burn off any condensation that gets in it it really doesn't matter how cold you motor runs. As far as the water pressure goes, it should be at 15 to 18 lbs at full running pressure (under way). Any excess can be remover with a pressure control valve.
I know everyone has a different way of doing this so get a few opinions and go with what you are confident in, that would be my suggestion.
