1 - 20 of 34 Posts
"Try it Now!"
In Fontana, one story home with ample attic space..need a ceiling fan installed. There is no box there now, and no switch either, just a wall switch going to a wall outlet.
Rather pay someone on here before i look in the yellow pages. Thanks!
Edit: The home was built in the late 80's if that helps at all.
The Insurance Guy
This actually isn't that difficult to do yourself. I am no contractor, have never worked a day in construction or electrical in my life and did this same install in our old house a few years ago on my own. Just had to get up into the attic, find an electrical wire going to an outlet, then spliced into it. To avoid the switch issue I used a fan with a remote control. Just a thought if you want to save a few bucks....
To be with code you're not suppose to mix plugs and lights... just sayin. You can probably find another ceiling light circuit to pull off of, not difficult work, just time consuming, and HOT this time of year in the attic. Also box needs to be braced well so fan doesn't wobble around.
The best thing to get is a remote control unit from Lowes/ HD etc if you have no switch and dont feel like pulling power from a switch box.
If your house has an attic light depending on the run you have to make you can pull power from that wire it up to the remote box and your done.
I could take a look in your attic for you but with the heat righ tnow it's no fun.
That depends on local codes. Its legal here. Its not usually acceptable for new construction, but they'll allow it many remodel applications. The one main scenario its allowed is when someone converts a switched outlet to an overhead light installation.
Not sure he does this kind of stuff but check with WishIknew here on the boards....you can't get a more honest stand up guy to do electrical work for you...
The Insurance Guy
Correct. When we sold the house, my install job passed the inspection. Only thing i did wrong was not strap down the wires. Couple staples and we were on our way
"Try it Now!"
Discussion Starter · #8 ·
Thanks for the info folks..i'm sure i can probably hammer it out myself..but wanted to have someone else do it as i don' thave the time
I stand corrected. I based that on what I was told by the contractor that did our office work here in San Dimas. So I'm sure it varies from locale to locale.
8anned
Isn't that Rancho Fontana? You know you can always raise the real estate prices by adding "Rancho" in front of any city. :)coffee
Or "Heights" to the end of it. I live in Compton Heights.....sounds nice, doesn't it.
Andy it's Fontucky, not Fontana.:)sphss
Apache Lake Monger
I've installed 3 in our house each time learned a little more and cleaner intallation. But my catch is this house has no attic:|err so its a bit of a biatch fishing wire in the walls and ceiling. I've gotten pretty good at patching holes drywall:D
1 - 20 of 34 Posts
