there was a friend of mine here that put a brand new arneson drive on a 2001 tunnel 22 ft daytona with 1350 hp and they couldnt make it work. He removed a b max drive that worked really well then the boat burned up beyond repair due to fuel injectors shooting fuel while he had plugs out spinning it over. Dumb move.So it appears no one has ever made the arneson drive work good on a small tunnel hull boat like a 19 or a 21 then.
Huge difference. There was Sanger/Skater true tunnel, 24 ft I believe, could have been a 23.One of Arneson's first boats that he used to run the Delta with was a 25' tunnel, Sanger I think, with a turbine eng. back in the early 80's.
Not a 21ft with a with a center pod stuffed up its ass.
I think Arneson's turbine was a 26.
They built them all the way down to 20ft. I know someone that had a 23 or 24, with outboards. I believe Arnesen built a smaller Alley Cat(23-24) with one of his drives, but I don't think Arnesen or anybody else stuck a turbine in one smaller than 26I believe they were 29 Sanger Alley Cats (he built 4 of them). I don't know if he built anything smaller than the 29's.
http://www.performanceboats.com/pb-open-water/110904-all-new-20-sanger-alley-cat.html
23' Sanger Alley Cat redo
1987 Sanger Alley Cat Power Boat For Sale - www.yachtworld.com
Yah, I was talking to Bob Leach on the phone one day and he was telling me about this surface drive boat an how it had so much tail lift that it would try to bury the nose and submarine. I bet it runs hard now with that I/O on it.They always looked like a good strong drive but it seems like they had too much tail lift for a small hull.
The Blackhawk on the smaller Daytona doesn't work either.Yah, I was talking to Bob Leach on the phone one day and he was telling me about this surface drive boat an how it had so much tail lift that it would try to bury the nose and submarine. I bet it runs hard now with that I/O on it.
I wanted to see it work also. I can see the challenges involved.. ..This is one I wanted to see work.
Oh well....I have entertainment here with gn7, haas, and unchained...that will get me bye
geezus thats a trailer step and a half right there...
REALLY:wtf:The Blackhawk on the smaller Daytona doesn't work either.
I believe you'll find that boat does not have nearly the same center pod as the 21 Eliminator. Not even close. In fact, as I remember, that boat had to be given a "hall pass" to run.REALLY:wtf:
funny,i have seen the Cheyanne (modVP bottom like daytona) with nascar motor and BH drive run lap times with the best at Enduro)THumbsUp
