...For the past eight years,...since I switched from the from the factory generator to a Delco alternator set up on my '63 Hallett,... the alternator will not begin to charge until I crack the throttle and give it some RPM???... ...If I do this once it will generally charge for the rest of the day even at idle... ...This was never an issue until last Saturday when I forgot to do this... ...I stopped to make a call on my cell phone and shut the boat off... ...When I went to start it,...no juice... ...Fortunately I was just outside Limesaddle Marina on Lake Oroville...
...Here are the technical details... ...The alternator is driven by the same pulley on the driveshaft that drove the generator... ...That pulley is a 4 inch as measured from the bottom of the v groove... ...the alternator pulley is a 2 inch... ...The crankshaft pulley that would have driven the original generator on an automotive 406 Ford is 6 inch... ...A good friend, although not a boat guy, has told me it may very well be a pulley size issue???... ...He says I may very well need to go to a larger size drive pulley???... ...Has any one ever had the same problem...
